Old 03-16-2020, 04:23 AM   #21
Originally Posted by Scheinin View Post
The part number for oil in my original post appears to be real oil and not synthetic. That is the oil my dealer put in at my last oil change in July. So, I will go to Walmart at get the equivalent, Super Tech SAE 15W-40 Heavy Duty.
You do know Super Tech is entry lever oil right?
Old 03-16-2020, 04:29 AM   #22
My manual says:
754 MAINTAINING YOUR VEHICLE
Engine Oil Viscosity — 6.4L Engine
Use Pennzoil Ultra 0W–40 engine or equivalent MOPAR
oil meeting the FCA US Material Standard MS-12633 for
use in all operating temperatures.
The engine oil filler cap also shows the recommended
engine oil viscosity for your engine. For information on
engine oil filler cap location, refer to the “Engine Compartment”
in this section.
Synthetic Engine Oils
You may use synthetic engine oils provided the recommended oil quality requirements are met, and the recommended
maintenance intervals for oil and filter changes
are followed.
Mopar Part No.: 68024967PC
OIL-15W40
Your manual says 0W-40 but you have been using 15W-40. Who's on first. Go with Rotella T6 15W-40. I run it in my 1300 Honda VTX1300 for 5 years and 50,000 miles.
Old 03-16-2020, 04:41 AM   #23
DouglasReid's Avatar
Originally Posted by W5CI View Post
I will admit I don't know what oil is in my Ram Cummins, I just take it to my dealer for oil change which cost me $45 by buying an ol change contract. otherwise it would be $65. I think a gallon of synthetic oil would be close to the $45
Shell Rotella T6, 5W-40 is $22.46 at Wallys place.
I do my own maintenance and engine holds 10 quarts so your $45 price is less than I can buy just my oil for.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 03-16-2020, 06:39 AM   #24
oil for 3500 Ram
My manual says:
in this section.
are followed.
This manual is for the 6.4 Hemi not the 6.7 Cummins Diesel
No more shoveling is offline   Reply With Quote
Old 03-16-2020, 06:52 AM   #25
TowPro's Avatar
My manual says:
in this section.
are followed.
in post 1 you said you need oil for your Diesel. a Cummins diesel engine is a 6.7l.
A 6.4L is a gas engine.
2019 Forest River Forester MBS 2401R
TowPro is offline   Reply With Quote
Old 03-16-2020, 07:04 AM   #26
My manual says:
in this section.
are followed.
I assume your truck has two manuals, one for the truck, which includes a gas engine, and another Diesel Supplement. Look in the Diesel Supplement to get the correct information.
The information regarding a gasoline engine in the main manual Is NOT applicable to your Cummins engine!
Diesel engines require oil specifically formulated for Diesels. The additive package for them are significantly different than oil for gassers.
Old 03-16-2020, 09:09 AM   #27
Jim34RL's Avatar
My manual says:
in this section.
are followed.
That isn't the Cummins engine, since 2007. 5 and up the engine size has been 6.7L in line 6 cylinder used in the Dodge/Ram trucks.
At the last two Cummins rallies that I have attend in 2013 and 2019, the Cummins and the Ram engineers have stress to us to use 5W-40 synthetic oil in the engine. Cummins has also stated all engines built since 2013 have been shipped with synthetic oil from the factory.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 03-16-2020, 09:59 AM   #28
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Correct!!!
These engines are not designed to run on 'dino oil' plus they can go up to 25,000 kms between changes which would be impossible on conventional oil.
Rotella or Amsoil are my oil of choice.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 03-16-2020, 12:53 PM   #29
My manual says:
in this section.
are followed.
As others have also stated, my post with the picture of the manual, came from the diesel supplement.
babock is offline   Reply With Quote
Old 03-17-2020, 12:36 AM   #30
Global Nomad
Scheinin's Avatar
Thank you, I misspoke. This is for the 6.7 diesel, from my diesel supplement:
In ambient temperatures above 0°F (-18°C), we recommend
you use SAE 15W-40 engine oil such as MOPAR,
Shell Rotella and Shell Rimula that meets FCA US
Material Standard MS-10902 and the API CJ-4 engine oil
category is required. Products meeting Cummins CES
20081 may also be used. The identification of these
engine oils is typically located on the back of the oil
container.
In ambient temperatures below 0°F (-18°C), SAE 5W-40
we recommend you use synthetic engine oil such as
MOPAR, Shell Rotella and Shell Rimula that meets FCA
US Material Standard MS-10902 and the API CJ-4 engine
oil category is required.
Traveling around the country, I am never in an area below O degrees. Therefore I use SAE 15W-40, stated in my original post.
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
Scheinin is offline   Reply With Quote
Old 03-17-2020, 03:50 PM   #31
container.
Yes but the synthetic version works for ALL temps. I always use synthetic oil whenever I can. As others have stated, you can also find 15W-40 synthetic that has the ratings required for your engine.
Old 03-17-2020, 06:40 PM   #32
I called Cummins when FCA couldn't tell me what oil was installed at the factory in my '19, though he wouldn't commit to the fact that they fill them at Cummins Rather than at the Ram factory he did tell me they use and recommend Valvoline Premium Blue 5W-40. My manual also says Mopar or Shell (though 10W-30 for 0 and above) I'm probably going to go with Cummins recommendations. Even if I go with Shell Rimula I'd still go with the 5W-40 it's good up to the same temp as 10W-30 and 15W40 but also good down below zero. It rarely gets that cold here but if it does I'm covered and it came out of the mouth of someone at Cummins not Ram.
19Ram3500
16Hemisphere302FK
Bear fans is offline   Reply With Quote
Old 03-17-2020, 07:01 PM   #33
My manual says:
I thougt the RAM diesel was a 6.7L. There is a gas 6.4L.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2018 RZR XP 1000 Ride Command
rskeans is offline   Reply With Quote
Old 03-17-2020, 07:27 PM   #34
Daycruiser's Avatar
Oil Threads.......
45 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
Daycruiser is offline   Reply With Quote
Old 03-23-2020, 06:37 PM   #35
bmwdave52's Avatar
Amsoil Signature Series oil for diesel. And their Ea filter.
bmwdave52 is offline   Reply With Quote
Old 03-23-2020, 07:40 PM   #36
Valvoline Premium Blue here 300,000+ still going strong. 7500 oil & Fleetguard filter cycle.
I may appear cynical but dealers are in business to sell vehicles not change their oil & maintain them.
Any cummins service (oil, filters, lube, & fluids) under a Benjamin is suspect. I spend $75+ a case for the oil alone, on Amazon.
Regards George & Cathy
Registry # 458
2008 28E33SA, Honda 3000 gen, Trimetric, RotoChocks,
2004 Dodge 3500 SLT 4x2 6.7L, 6spd, DRW,
BrakeSmart controller,
Garmin NUVI 755
SCClockDr is offline   Reply With Quote
Old 03-23-2020, 08:02 PM   #37
TSC had Valvoline Premium Blue 15-40 on sale for 11.99 per gallon. I bought 9 gallons. Cummins has a tsb out about C J4 oil being permitted but CK is recommended. The CK4 oil spec has some specs that relate especially to the Cummins ISB and ISX engines. I’m going to run dino 15-40 in mine because 20 degrees is record lows for us. If the oil meets or exceeds the CK4 specs and CES 20086 it’s good to go. The brands and colors of jugs are for the owners. The ISB Cummins is not picky at all about what brand is used. Look at all the third world countries where they use what ever rendition of motor oil they have.
Always at home regardless of where we are
OLEJOE is offline   Reply With Quote
Old 03-23-2020, 08:05 PM   #38
Just roll into your local dealership and pickup what you need.
Nastynotchback1 is offline   Reply With Quote
Old 03-23-2020, 11:17 PM   #39
Rockinh's Avatar
6.4l
Just to be clear, the 6.4l engine is not a diesel engine. the Cummings diesel is a 6.7l.
My manual says:
in this section.
are followed.
RockinH Bill
2019 Silverback 37RTH
2014 Shadow LQ 3 horse select
2015 Ram Laramie DRW
2012 Concourshttps://www.forestriverforums.com/forums/images/smilies/roflblack.gif
Rockinh is offline   Reply With Quote
Old 03-24-2020, 02:37 AM   #40
Just a member
kandl's Avatar
Cummins does not fill (oil) engines destined for Saltillo. FCA (Ram), has, since about 2013, filled the engines with a Shell product. That's when they punted Exxon/Mobil out of bed and cuddled up with Shell.
For MY 18 and back to 13, factory fill was 15W-40 and interwebs intel suggests that it was Rotella T5 Semi-syn.
For MY 19, FCA switched gears and shipped the trucks with 10W-30. It is, anecdotally, Rotella T5 Semi-syn.
The Cummins engineers at the rally were perhaps pushing the envelope?
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
kandl is offline   Reply With Quote
3500, 500, diesel
