Old 12-13-2019, 02:18 PM   #41
koller1509's Avatar
Originally Posted by whiterose View Post
You should always use the dead bolt, spring loaded latch is insufficient. If you used the dead bolt then it was out of adjustment.
Side handle should have sufficient index to hold the door when folded in the correct position
Sorry popeye, only saw your comments after sending mine.
It was his outdoor kitchen door that opened, not his main door.
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
koller1509 is offline   Reply With Quote
Old 12-18-2019, 08:34 AM   #42
Seanpd
Seanpd333's Avatar
This happened to me, though I didn't damage any other vehicles, I damaged the door severely when I pulled over and it hit a sign. (I did not know the door was open, just had a driver shouting at me to get over. For those judging about mirrors, I'm here to tell you that on my rig at least you CAN NOT adjust your mirrors such that you would see the outside kitchen open. Believe me I have tried. To ensure I never have another such disaster, (cracked the hinge, damaged the door, tore off both hydraulic lifts, lost some items from inside) I replaced the locks with longer catches, and I added an additional clip as a fail safe. Before spring I intend to add that to all hatch doors. We do a very methodical check before rolling out, each and every time, so it was certainly not an unlatched door.As with many issues with my FR surveyor, this is a design flaw that I have had to compensate for.
2011 Forest River Surveyor SV 305 Arctic package
2017 F250 Lariat 6.7 L Diesel
US Army Sergeant Major
Seanpd333 is offline   Reply With Quote
Old 12-20-2019, 12:50 AM   #43
Dodge Guy's Avatar
Is this a new RV? If so, and you prove that the door doesn't latch properly then they should (better!) repair it. Let the NHTSA know this happened also. They need to know about dangerous issues like this.
As for the damage to other vehicles, if FR fixed the door because of the failure then the insurance company can go after FR for compensation.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 12-20-2019, 11:20 AM   #44
BillyBass's Avatar
This doesn't have anything to do with the outside kitchen.But I went to Gettysburg and my inside sink cave in. So I call the dealer and they fix it
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
BillyBass is offline   Reply With Quote
door
