Old 09-15-2020, 10:28 PM   #1
Oven problems
New to the RV World. Just got my first RV it old but in good shape. The oven is not working right. Pilot light comes on fine. When I turn to Broil is coming on. But it only works on broil. Turn is down and the fire goes out but the pilot stays on.
Cdhamner is offline   Reply With Quote
Old 09-16-2020, 08:36 AM   #2
SeaDog's Avatar
welcome to the forum its a great place to get your questions answered. On broil the unit is calling for heat all the time. When you turn the knob down it may be going to a bake mode and shutting down flame until the temp is reached. have you waited to see what happens when you change the position of the control knob?
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-16-2020, 08:43 AM   #3
It could be as SeaDog said or it could be the control unit is bad and not calling for heat when in temp control mode.
Give us the make and model of the oven and maybe we can help more.
Gotta go campin!
Old 09-16-2020, 09:44 PM   #4
R1740bb made by Atwood it says Wedgewood on the outside of the stove
Old 09-24-2020, 03:38 PM   #5
Any ideas?
Old 09-24-2020, 03:57 PM   #6
There's not much info on that model.
You could try replacing the thermocouple as that's a pretty inexpensive part.
Gotta go campin!
Old 09-24-2020, 04:25 PM   #7
U.S.ArmyVeteran's Avatar
Just an FYI,
ATWOOD IS NOW DOMETIC
Beginning in 2017 Atwood is sold under the Dometic brand.
Depending on the age of your trailer may not have any info. But may be worth a call.
Good luck
U.S.ArmyVeteran is offline   Reply With Quote
Old 09-24-2020, 06:24 PM   #8
Just as confused as you
Scrapper's Avatar
I have found that Atwood usually goes by the serial number instead f the model number. If you have the the serial number the links below might help.
https://techsupport.pdxrvwholesale.c...d-range-stove/
http://techsupport.pdxrvwholesale.co...twoodrange.pdf
https://www.hunker.com/13409372/how-...gewood-rv-oven
Richard & Jill
