Old 01-04-2021, 08:17 PM   #1
Overnight camping
We are planning a trip to Florida from Indiana.I would like to know if I should unhook my camper just for overnight stop,or is it ok to leave it hooked to my truck and just make sure its level.It,s a rockwood pull behind with 2 slides.
Kamper Kruzer is offline   Reply With Quote
Old 01-04-2021, 11:19 PM   #2
Always Learning
There’s no need to unhitch. Your camper takes more abuse going down the road than you’ll inflict on it by walking around. Do make sure you’re reasonably level for the slides and the fridge.
Pros to unhitching include being able to run for fuel, food, or even an easy get out easily in an emergent event.
Pros to staying hitched, it’s just easier!
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
ependydad is online now   Reply With Quote
Old 01-05-2021, 12:00 AM   #3
Roddor's Avatar
We would leave our trailer hooked up and would put the tongue jack down to help stabilize it or adjust the level. It also takes some load off the tow vehicle suspension. We were heavy on our tow vehicle.
Just make sure to put up your tongue jack before you drive away.
2018 Coachmen Concord 300DSF
2018 Jeep Wrangler JK Toad
Roddor is offline   Reply With Quote
Old 01-05-2021, 12:09 AM   #4
If you can get your camper level with it connected, leave it connected. We have done it with our former TT and now with our 5er.
2017 Keystone Cougar 28RDB
Buck1032 is offline   Reply With Quote
Old 01-05-2021, 01:43 AM   #5
Yes, if somewhat level just leave er connected. A little less time in the morning when leaving.
Where are you going in Florida?
2016 Siverback 33IK, Towed 40K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
dalford is online now   Reply With Quote
Old 01-05-2021, 01:43 AM   #6
We always left our camper hooked up when we stopped overnight.
If you're going to camp at a site that has an electrical hookup, disconnect your connection to your tow vehicle. We had a friend who didn't disconnect and had a feedback into his truck. Cost him thousands to replace all the electronics the shorted out in the truck. Just make certain you reconnect before taking off.
If you're not connected to electric, just park and level the best you can.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 01-05-2021, 10:52 PM   #7
Overnight, I stay connected. However, if you are going to boondock off the batteries, unplug the 7-pin connector. My 12 volt aux on my van comes straight off the vehicle battery and if something went really wrong, I'd rather drain the trailer batteries rather than both trailer and vehicle batteries!
A lot of tow vehicles with from the factory trailer connections, though, disconnect the 12 volt aux to the trailer from the vehicle when turned off and you would always be OK then.
Always make sure to do your pre-departure checks the next morning too. Trailer still locked onto hitch ball, 7-pin cable connected, tongue and stabilizer jacks all raised, etc.
NavyLCDR is online now   Reply With Quote
Old 01-06-2021, 10:40 AM   #8
On an overnight we stay connected unless the tow vehicle is needed for a run into town.
I typically level both directions using the Levellr orange blocks and the tongue jack. Usually don't bother with the stabilizer jacks. And I disconnect the trailer electrical plug, since mine is an always on connection. If the site has electrical, I may or may not use it, depending on need/desire for A/C and/or microwave.
Fred W
2019 Flagstaff T21TBHW A-frame
Old 01-06-2021, 10:48 AM   #9
Agree with all these fine posters...no need to unhitch. I DO level out as best I can though
TV - 2020 RAM 3500 Mega Cab SRW with 6.7 Cummins HO & Aisin 6 spd, 4k payload, 23k towing
2002 GMC Yukon XL 2500, 8.1 liter (496ci), 4L85e & positraction with 3.73 gears
TT - 2013 Dutchmen Aspen Trail 3130 QBS
Great bourbon-just about any of San Diego’s craft beer
Beachbourbon is offline   Reply With Quote
Old 01-06-2021, 10:51 AM   #10
That shouldn't be the case in any way. There's something fishy going on there.
aeblank is offline   Reply With Quote
camping
