Old 01-24-2022, 02:29 PM   #1
portable generator/air conditioner issues
I have a 2018 Surveyor that is driving me batty. I power up my Honda2200 generator and when I turn on the air conditioner the generator powers down and a cautionary light goes on. New to all of this so any help would be appreciated.
Thanks,
camper 4 life is offline   Reply With Quote
Old 01-24-2022, 02:40 PM   #2
Trailer Trash
Captain Insaino's Avatar
Research Softstart RV or Easy start Micro air
2017 Palomino-Real-Lite Mini-RL-177
Typical Boondocking mods
Captain Insaino is offline   Reply With Quote
Old 01-24-2022, 02:40 PM   #3
Kcoulter's Avatar
Have you tried a soft start system, like the Microair Easystart?
2020 Flagstaff Micro Lite 25BRDS
2021 Ford F-350 XLT 6.7L Power Stroke
Kcoulter is offline   Reply With Quote
Old 01-24-2022, 03:45 PM   #4
As alluded to above, sounds like your generator doesn't have the wattage to get the A/C started. My previous trailer didn't have a built-in generator, and I tethered 2 Honda EU2000s together when I needed to use my A/C. So, buying a second Honda generator would be an option (albeit a costly one).
https://powerequipment.honda.com/gen...lel-capability
The EasyStart suggestion is a good starting place, though. It will allow you to get the compressor started on the A/C with less watts, and then your single generator should be able to run the unit once it's gotten going.
Greenhound386 is offline   Reply With Quote
Old 01-24-2022, 11:28 PM   #5
Guspech750's Avatar
You’ll need a soft start for the AC or run two Honda 2200’s in parallel to generate the amount of electricity needed to run the AC along with any other needs.
Or do both. Get a soft start and a second Honda 2200. You’ll have the best of both worlds.
Tow vehicle: 2017 Ford Expedition XLT EL factory tow package. Added towing mirrors, 10 ply tires on separate rims, sumo springs, larger rear sway bar.
2021 Cherokee Greywolf 23MK
Equalizer 1,000lb WDH
Guspech750 is offline   Reply With Quote
Old 01-25-2022, 12:43 AM   #6
Is it a 13.5k or 15k A/C? MicroAir Easy Start should help with the 13.5k but I'm not sure what the start up load is for the 15k.
And if your batteries aren't 100% turn off the breaker to you converter so it's not trying to pull extra amps.
2021 Flagstaff 21DS
2015 Silverado 2500HD (overkill but convenient)
Renogy bits: 3000W Inverter/Charger, 400Ah LiFePo4, 40A DC-to-DC
Rich Solar bits: 400W of panels, 40A MPPT
Misc bits: LevelMatePro+, SolidRemote based wireless controlled LED storage lighting
jbflag21ds is offline   Reply With Quote
Old 01-25-2022, 11:02 AM   #7
portable generator/ air conditioning
I'm using a Honda EB2800 generator so i'm pretty confident that the power source is sufficient. The trailer is 2018, could the AC unit have crapped out already? Or could it be a maintenance issue. If so, could someone walk me through whatever steps would be proactive.
Thanks,
Old 01-25-2022, 11:10 AM   #8
The ac unit will use all the output of the generator.
Can we assume the water heater, electric fridge, converter and other large electric power users are off.
tomkatb is offline   Reply With Quote
Old 01-25-2022, 11:14 AM   #9
Thanks,
Does the A/C work when plugged into shore power?
2800w is still on the upper fringe of starting an A/C (especially a 15k unit) unless you have made mods to the A/C and are positive ALL other circuits (especially water heater and CONverter) are off at the breaker.
And yes, it could have crapped out. There are tons of posts about A/C units failing because of various reasons. Other than cleaning the condenser coils periodically, checking for mud dauber nests and cleaning the interior filter(s), there is no A/C maintenance.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=88
Old 01-25-2022, 11:30 AM   #10
I have a 13.5 BTU AC with a soft start and still need two A i-Power 2350/1850 generators to run it off grid.
Once the compressor is running it will usually run on one generator while the second basically idles. You see the second generator kick in when the compressor comes on. My gensets show the load they are each handling on a digital display. That's how I know this.
2021 Palomino SS1251
2004 RAM 2500 SLT HD Cummins
2019 Tracker 165WT
rdailey is offline   Reply With Quote
Old 01-25-2022, 12:13 PM   #11
Kcoulter's Avatar
I have a 15k with MicroAire Soft Start and have no issues with a single Honda 2200.
Have not run into an issue with the converter adding too much load either. Definitely won't run the electric water heater, coffee pot or microwave at the same time as the AC.
Old 01-25-2022, 12:29 PM   #12
In your original post you said you were using a Honda 2200 generator. Which is it - - 2200 or 2800?
Which AC do you have - - 13.5K or 15K? It makes a big difference.
Honda EU2200i = 2200W startup & 1800W continuous
Honda EB2800 = 2800W startup & 2500W continuous
13.5K AC requires 2750W to start & 1250W to run after start
15K AC requires 3500W to start & 1500W to run after start
If you are using that 2200W genny, it will not start either AC without a soft start.
Even the 2800W genny won't start a 15K AC. It would start a 13.5K AC - barely. If you have any other load going it may not - - which could be what is happening.
Either way, just because you think your genny is big enough does not make it so. My guess is that your AC is fine, you just need a bigger genny or a soft start.
BTW, that EB2800 is an open frame, industrial generator. Your neighbors won't be happy about you firing that thing up in a campground.
yukongold is offline   Reply With Quote
Old 01-25-2022, 12:41 PM   #13
Flybob's Avatar
It is not your AC. Your generator is not up to the task.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-25-2022, 01:10 PM   #14
bikendan's Avatar
Thanks,
OK, which Honda do you have? You posted two completely different models.
Also do you have a 13.5k or 15k a/c?
Old 01-25-2022, 01:14 PM   #15
I also have a 15k with a MircoAire, and have no issues with my 15 year old Honda eu2000.
2020 Gray Wolf 26RR
2016 Tundra TRD Pro
edc1911 is offline   Reply With Quote
Old 01-25-2022, 01:16 PM   #16
I run my 13.5k A/C with a honda 2200 just fine, but I added a micro air easy start. Search google or youtube for videos. As others stated, your A/C if probably fine, your generator isn't powerful enough to start the air conditioner.
m
2014 Flagstaff Shamrock 21SS
2018 F-350 Crewcab Lariat 4x4 6.7 powerstroke
Deputy Fire Chief-09-11-2026 retirement!!!
hybridlife is offline   Reply With Quote
Old 01-25-2022, 01:25 PM   #17
U.S.ArmyVeteran's Avatar
Thanks,
Your original post said: Honda2200
So everyone is as confused as me .....
U.S.ArmyVeteran is offline   Reply With Quote
Old 01-25-2022, 01:29 PM   #18
Our Westinghouse 2500/2200 runs our 15K Air unit on our Surveyor just fine.
But, I don't let anything else with a high load run simultaneously.
I also start the fan on auto and let that run for a bit. Then turn on the actual Air Conditioner. Runs just fine.
Good Luck.
Old 01-25-2022, 02:35 PM   #19
Same for me. But, when using the AC with Honda 2k generators they are a lot quieter when running both units paralleled together.
emm-dee is online now   Reply With Quote
Old 01-26-2022, 02:31 AM   #20
Retired Engineer
What elevation are you at? Internal combustion engines lose power with altitude. I don't remember the exact numbers, but at 8000 feet MSL your 2200 watt generator provides about 1500 watts. With our 2019 Surveyor, our 2500 watt Westinghouse generator powers the air conditioner just fine most places. In the mountains it wasn't enough, so we added a Soft Start to the air conditioner. My guess is that a Soft Start may be enough for your 2200 watt generator to work near sea level (or in the Midwest), but not in the Rocky Mountains. You will probably need more generator there.
bcramer is offline   Reply With Quote
air conditioner, generator
