Originally Posted by mgoulet21
three prong outlet and it appears to be a gfci outlet
yes, I am using an adapter
are you possibly tripping the gfci outlet at your house? It is a known issue that some RV's and the leakage current from various sources (like a converter) will often times trip a gfci outlet at a house.
Have you plugged in other items into this gfci outlet to make sure it has not tripped.
The gfci outlet will have a reset button on it.
Are you using any kind of extension cord between the RV's shore power cord and the outlet.
