Old 01-20-2016, 08:22 AM   #1
Camp Bartender
Power stab jacks?
The power stab jacks on my Wilderness 28DBUD have a lot of "give" to them when they are down, meaning when some were to say walk up and down the steps, the camper has a lot of side to side give to it. The dealer says this is normal, but I cant see how it is. Even for my wife who is very tiny (5-1) they give a lot. Front to back isn't bad thanks to my x chocks, but does anyone else experience this?
2017 Dodge Ram 1500 Big Horn, 5.7L HEMI
2015 Forest River Wildwood 28DBUD
2015-2018: 20 Trips, 61 Nights Camped
2018: 5 Trips, 15 Nights Camped
2019: 2 Trips, 10 nights so far......
stevensmith2859 is offline   Reply With Quote
Old 01-20-2016, 08:49 AM   #2
Add Step supports also! Lots of leverage on steps! Youroo!!
Old 01-20-2016, 08:50 AM   #3
TURBS's Avatar
Jt strong arms period.
http://www.lci1.com/jt-strong-arm
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-21-2016, 10:38 AM   #4
Camp Bartender
That's a great idea! Thanks for the tip!
Old 01-21-2016, 10:43 AM   #5
AquaMan's Avatar
Also, the further down the jacks are from the frame, the less effective they become. If possible, try putting blocks under the jacks to reduce the amount of travel. Wood or "lego" blocks work well.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 01-21-2016, 10:47 AM   #6
Camp Bartender
I plan on building some jack pads out of pressure treated lumber this spring. I figure the trailer does sit up really high, so it makes sense that two "lego" blocks under each pad would really do a dang thing. Adding tall pads, and the jack under the stairs should help the sway a decent amount.
Old 01-21-2016, 11:05 AM   #7
If you look at the design of the stab jacks, the jacks slide on a channel and the farther down the legs go, (as close to vertical as possible) the less tendency they have of sliding from side to side. I reinforced the legs on the rear jacks and the axle jacks and try to get them as close to vertical as possible. Don't have the side to side movement at all. Putting blocks to keep the legs as high as possible just aggravates the side to side problem.
Old 01-21-2016, 11:24 AM   #8
fonzie's Avatar
X2
Fonzie
Old 01-21-2016, 11:30 AM   #9
TURBS's Avatar
Power stab jacks?
Your talking about the rear and in your case also the middle stabilizers not the front landing jacks am I correct?
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-21-2016, 11:52 AM   #10
Members
Tommy Joann's Avatar
JT's Strong Arm Jack Stabilizers
Thanks for the web site info!
2018 Salem 28RLDS Showstopper Package
2015 Chevy Silverado Crew Cab LT Sport
Husky Centerline WDH
Tommy Joann is offline   Reply With Quote
Old 01-22-2016, 10:20 AM   #11
Camp Bartender
Thanks for all the ideas÷
Old 03-30-2016, 12:34 PM   #12
Camp Bartender
To get back to this, what would you do in a situation that doesn't allow for the jacks to fully extend? This just doesn't seem right how much side to side movement there is.
Old 03-30-2016, 02:46 PM   #13
Always Learning
As TURBS mentioned, the fix is to add triangulation stabilizers. He linked to the JT StrongArms whereas I'm a fan of the SteadyFast system (less bars, less moving parts, and way easier on the hands for tightening).
Old 04-01-2016, 12:06 PM   #14
Camp Bartender
Forest River is actually sending me 2 new switches and 2 6 amp mini breakers. They said on the 2015's and older, the motors basically cannot push down hard enough before the factory installed mini breakers pop to actually keep it from swaying. They claim this is the "fix" plus they are also sending me a touch screen remote to control my camper for the "hassle"
jacks, power
