Old 06-13-2017, 07:12 AM   #1
Pressure Washer Recommendatiions
Does anyone have experience with:
Worx 20-Volt Hydroshot Power Nozzle 325 PSi-WG629 - The Home Depot
I am looking for some gadget to help with the exterior maintenance.
Thanks in advance!
delunderpar is offline   Reply With Quote
Old 06-13-2017, 11:25 AM   #2
based on the reviews it looks like its pretty weak.
I just bought an electric pressure washer. They are much ligher and more compact than a gas pressure washer so they are much more user friendly. The pressure is less than a gas one, but that is only an issue if you use it on your driveway.
Its perfect for washing cars/trucks/campers because it only runs when you pull the trigger. Unlike a gas one, that you would have to start/stop the engine.
And its easy to drain it and carry it to the basement for the winter, so you don't have to worry about freezing.
mkosu04 is offline   Reply With Quote
pressure
