Old 02-17-2020, 07:44 PM   #1
Rear Stablizers
I have a Salem Hemisphere and the rear stablizers are not working as I would expect. Since this is our 1st RV I'm not certain about how they should operate. Anyway, when I put them down they do not go down together all the time. Sometimes one starts down and moves 2-3 inches before the other starts. Of course we are not always on level ground and sometimes one goes down further than the other ( I do try to block to the same height for each). How are these things suppose to work??? When I retract them, 1 almost always get one that's up before the other; is this normal?
Thanks!
Aaron2018 is offline   Reply With Quote
Old 02-17-2020, 07:49 PM   #2
onetonford's Avatar
Yes that is normal for the electric stabilizers as they are self leveling but don't try to level with them as they are not levelers and should only brought down till snug against the ground. i also check mine daily as they tend to loosen up with movement.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 02-17-2020, 07:49 PM   #3
totally normal and working like it is supposed to. my heritage glen does the exact same thing. just hold the button and let them work. I put chunks of 6x6 treated under mine because they have more support when not fully extended.
Kimber45 is offline   Reply With Quote
Old 02-17-2020, 08:21 PM   #4
Wow!!! I would not have thought they would work that way! It's great to have you guys input! I don't fill like I have a problem/issue now. Thanks for sharing your experiences!
