07-04-2020, 03:14 PM
Reattaching a Loose Trim Strip
Our Rockwood Mini Lite 1909-SG has an above the bed storage bin that runs the width of the trailer at the front. On our last trip out I noticed the trim strip on the inner wall where it curves to the roof slowly peeling away on the left side of the storage bin (Pic). There are two access doors (Pic) but it's a real stretch to get from the door to the left end of the strip. I think to would probably be simpler to remove the entire strip and then reinstall. Thoughts?
Thanks,
TBDub
07-05-2020, 06:57 AM
Same Problem
I have the same problem; I was debating whether to use adhesive along with some finish nails.
07-05-2020, 07:03 AM
Part-Time Campground Host
X2
I use some "Liquid Nails" and a few nails or staples. The ones I've done in our camper have never come loose again.
Craig & Cath
Days camped since 2015(retirement): 1651
07-05-2020, 07:12 AM
I would just use a length of double-sided tape instead of any sort of glue, just in case you need to pull that strip off one day.
Bruce
07-05-2020, 01:55 PM
Glue it with the best glue you can find, but have a 1/4 in plywood or some "stop sign" (thickness) material and press it firmly in place with 2x4's or other types of poles to hold it in place while drying.
Glue must be light enough (watery) to no cause bulges or air pockets. Watch a YouTube on wall paper hanging or similar before you begin. Remember: ONLY YOU WILL KNOW YOUR WORK'S FLAWS and if that bugs you take it slow.
07-05-2020, 02:07 PM
I have a Harbor Freight Central Pneumatic 18 gauge 2 in 1 nailer and stapler that I keep in the trailer for just trim pieces....a little wood glue and pin nail and you are good...with all the twisting and turning they come loose. I use the 1" pin nail, seem to hold good...
Dave...Northern Nevada
2018 Rockwood 8299bs
2007 GMC 2500HD Diesel SLT short bed w/gravity flow75 gallon Fuel Tank.. Cat delete
Firestone Airbag Ride Rite system
07-05-2020, 02:54 PM
It may be better to take it out and glue the entire strip. It would be suggested to use masking tape on the cieling above and below the strip edges before removing. This will give you a guide line to reinstall. It will also stop accidental glue on the ceiling. Depending on what glue you use, you may also want to use tape to hold it in place while it dries.
07-05-2020, 08:46 PM
I had a small trim piece let go. I think there was one tiny staple. Removed totally and applied a 3M adhesive glue. I was able to wedge some cardboard to hold it in place till dry. See no problem using a wire nail here and there while the glue sets as was suggested.
07-05-2020, 11:18 PM
Trim
Use Weldwood w/ a small 1/4" brush. I use ones designed for fiberglass, stiff bristles. Also called gauss brushes. Put Blue painters tape around anywhere it would drip. Pull tape as soon as you stick pieces together. Follow instructions on the bottle. Put a few nails in after. I have redone several wall panels and they have stayed put for 10K of towing on my V-Lite. Have someone help you, once you put the pieces together, Done.
07-06-2020, 08:43 AM
Loose trim
Good Luck trying to remove the trim to put glue on it, it was installed before the cabinets.
07-06-2020, 08:56 AM
Don't Camp Enough
I have had similar issues on past and present campers. I have successfully used a hot glue gun on loose wood trim and wallpaper. I find it is controllable in application and forgiving.
2020 Prime Time Sanibel 3102
2016 F-350 King Ranch
Trim
I would just pul back an edge, put a spacer in to hold it out. Then put a thin coat of Weldwood on both sides, give it 5 minutes, pull spacers and push together. Probable better not to take trim off, easier to keep it lined up.
07-06-2020, 11:44 AM
Contact cement and brads
Plenty of good responses. I had a major trim piece over the slide out fall out, it was too long so it bowed in the middle and wouldn't stay put. I removed and shortened. Masking taped trailer side, contact cement on trailer and trim piece, 10 min to get tacky. Then, you get ONE SHOT to get it in the right place, two pairs of hands came in handy here. A couple brads from a pnuematic stapler to hold till curing, rock solid.
Depends on your skills, tools and helpers. Modern adhesives are pretty amazing, so seems many other solutions are good.
