Old 05-19-2020, 04:25 PM   #1
Removing Sticky Rubber from TT
I'm in the process of replacing the exterior D seals around the bump out openings. The TT is 9 years old and the rubber seals have deteriorated. I've purchased replacement seals but need to clean the sticky rubber from the slide out flanges. I've searched this forum for the best methods to do this but haven't found anything. Maybe I'm using the wrong keywords. Anyone have experience with this? Thanks in advance for your help!
Leigh8314bss
ID:	229421   Click image for larger version
leigh8314bss is offline   Reply With Quote
Old 05-19-2020, 05:38 PM   #2
Chris Pastuzyn's Avatar
Have you tried goo gone? They have several different types, WD40 will remove some glues.
Chris Pastuzyn is offline   Reply With Quote
Old 05-19-2020, 05:41 PM   #3
3M Stripe Off Wheel is the best tool I have seen for this. $33 for two including drill adapter. It will not harm the surface.
https://www.amazon.com/Stripe-Wheel-...NsaWNrPXRydWU=
2019 Cedar Creek 29RE
2017 Silverado Duramax 3500
rocco52 is offline   Reply With Quote
Old 05-19-2020, 07:31 PM   #4
It only comes with one, but the reviews are very good. I just ordered one. I like to remove and replace the badges on my truck a lot and this should handle the leftover adhesive with aplomb.
corn18 is offline   Reply With Quote
Old 05-20-2020, 01:48 PM   #5
rsdata's Avatar
I have been using this to remove adhesives for years... will not harm your trailer finish
2014 Shamrock 183
Old 05-20-2020, 05:14 PM   #6
Goof Off or Desolv-it. Both citrus based, removes graphics glue great.
nayther is offline   Reply With Quote
