Old 10-16-2020, 01:40 PM   #1
replacement lights for 2014 Silverback
Iím looking for replacement lights for the ceiling in a 2014 Forest River silverback camper. The company that made them are no longer in business. And even though they were warranted for life there unavailable.Click image for larger version
sg47619 is offline   Reply With Quote
Old 10-16-2020, 08:11 PM   #2
httntheroad's Avatar
Cedar creek is really good about sending replacement led lights at no charge.
httntheroad is offline   Reply With Quote
Old 10-18-2020, 09:00 AM   #3
They tell me they are no longer available. Didnít know if thereís was another company that has them.
Thanks Steve.
Old 10-18-2020, 09:16 AM   #4
jrk341's Avatar
Maybe try Optronics.
TV:2019 F350 6.7L Diesel
RV: 2018 Coachmen Apex 249RBS
jrk341 is offline   Reply With Quote
Old 10-18-2020, 03:22 PM   #5
Thanks Steve.
Ask them to send you new puck lights. If you are in warranty they should send you enough to redo the entire set so everything remains uniform.
Prolly cost them 10 lbucks
campers302 is offline   Reply With Quote
Old 10-19-2020, 05:21 AM   #6
The OP's 2014 unit is probably not under warranty anymore. Cedar Creek is more than likely going to send the whole light. I had a light issue and they wanted me to send them pictures of the whole unit.....it took a few tries on their part before they finally sent me the correct unit. There are several different puck style light fixtures.
Good Luck.
Mike K
2019 Cedar Creek 34RL2 w/disc brakes
2017 GMC 3500 D/A, DRW, 40Gal Aux Tank
USN 76-82
Retired Dept of Navy: Navy/USMC Flt Test Engineer
Splashes3 is offline   Reply With Quote
Old 10-19-2020, 07:30 AM   #7
We have/had the same lights in our 2015. Several of them have failed over the years, some when the trailer was under warranty and some after the warranty expired. Even when the company that manufactured them was in business getting them to send replacements was an ordeal to say the least. I didnít try Forest River. I ended up replacing most of ours with some that are slightly larger but also have a push button switch in the center of the light. I believe the picture that was provided is of a light that has an external switch as opposed to a switch on the fixture itself. I actually prefer the switch on the fixture itself as even when there are several lights controlled by one wall switch I can turn off individual lights if I want or have them all on and controlled by the wall switch but thatís just personal preference. The ones that I replaced them with I bought from the dealer where we purchased our rig. They couldnít get the originals either. I donít remember the name of the manufacturer of the replacements but they are a pretty generic item. If memory serves they were about $10.00 each and they are far superior to the originals. None of the replacements have failed.
Good luck.
Flatlander
2015 Silverback 29IK
2010 Silverado 2500HD LTZ
6.6 Duramax / Allison 1000
Flatlander49 is offline   Reply With Quote
Old 10-19-2020, 10:02 PM   #8
Ok thanks Iíll try them
