replacement power module for Dometic DMR702
Have had two circuit boards go out in two years, usually in connection with an overheating event (running in gas mode while on the road) which also takes out the inline thermal switch. I will address the heat issue with supplemental fans but need to know where I can get the DMR702 power board p/n 385 13 31-01 to keep as a spare.
