Old 03-17-2020, 04:16 PM   #1
Rockwood Geo Pro 12RK inverter / microwave
I have had this brand new Rockwood Geo Pro 12RK for less than a week. Does anyone know if the microwave will run from the battery / inverter power? The salesperson told us it would but I did not test it when purchasing it.
JGD1953 is offline   Reply With Quote
Old 03-17-2020, 04:41 PM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. I very much doubt your rig has an inverter installed. that rig comes with a 3 way frig meaning 110v/propane/12v. you have a converter for supplying your 12v and 110v power needs. The microwave only runs when plugged into shore power or on your generator
Retired Navy
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 03-17-2020, 04:50 PM   #3
Thanks for the reply. It does have an 1 KW inverter as the circuit breaker on it popped and I had to pull out the refrigerator to reset it. The frig is only 110 AC (not propane) and works off city power or the inverter.
Old 03-17-2020, 04:58 PM   #4
SeaDog's Avatar
Good deal, the standard package was what I was referring to. If the microwave is not plugged into that same inverter circuit as the frig then it should not work. easy way to tell is unplug from shore power see if the frig stays on and see if there are any lights on the microwave if its lit then it is receiving power from your inverter.
Retired Navy
geo pro, inverter, microwave, rockwood
