Old 07-14-2024, 04:11 PM   #1
larry2c's Avatar
RV Airflow vs cold shower
Not sure if this is the right place to ask this question so if the Mods feel it should go elsewhere, please make it happen.
I've been looking at the RV Airflow system to improve the flow AND make things quieter in our TT. We have the Dometic Brisk Air 2 and it cools OK but it seems to always be running with the fan on high (using Auto mode) and it makes having normal conversation pretty difficult. For me it would be a no brainer to get the RV Airflow system but... DW likes to use the "cold shower" on occasion and she's hesitant to give it up (it appears to eliminate that output - if I'm wrong on that let me know). If the system would improve the cooling in the trailer enough she'd probably not mind not having the cold shower.
So that's my question to anyone who's installed this in their RV. Did it make a big difference in the overall cooling of the RV? Did you miss the cold shower from the original A\C?
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Only one shedding mutt now RIP Yoshi
larry2c is offline   Reply With Quote
Old 07-14-2024, 04:42 PM   #2
The “dump” as we call it more or less short cycles the AC so it’s not really a benefit. My father in law and I did a DIY version of this with foam and tape. 3 years in I wouldn’t change a thing. It’s quieter, and it went from barely blowing out the ducts to—and much to our surprise—blowing paper towels off the table when it kicked on the first time.
110% worth it in my opinion.
Tex94 is online now   Reply With Quote
Old 07-14-2024, 04:47 PM   #3
Enjoying Life
Have installed the unit and it works. Don't miss the "dump" because the air from the ducts is stronger.
2022 Rockwood 2109S
Previous: Rockwood 2608WS, 2608BSD
2006 Durango HEMI
TeachTexas is online now   Reply With Quote
Old 07-14-2024, 05:13 PM   #4
I did the DIY method much cheaper
https://www.google.com/search?q=vide...t=gws-wiz-serp
+ go around looking at places to fix air leaks through door/ slides /windows
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 07-15-2024, 06:46 AM   #5
Retired Old Guy
IamProStreet's Avatar
I have the RV Airflow in my living room AC and it works great, don't miss the dump because we never used it as it’s too high to reach. I was thinking about doing the DIY version in the bedroom because it will retain the dump feature for the wife and quite the AC while running and improve the air flow.
IamProStreet is offline   Reply With Quote
Old 07-15-2024, 10:32 AM   #6
larry2c's Avatar
Thanks to all for the replies. I may try the DIY version first to see how it works - I'm as interested in quieting things down as much as getting better airflow. Hopefully it will give me both!
'11 F150 5.0
Old 07-15-2024, 12:58 PM   #7
Totally worth it! Especially if like me someone ran the wires through the opening
ID:	302057   Click image for larger version
ID:	302058   Click image for larger version
Old 07-15-2024, 02:53 PM   #8
I installed the Koolrv duct and am happy with it. Lowered the fan noise also.
BADinc is offline   Reply With Quote
Old 07-15-2024, 03:09 PM   #9
I installed the Wacko RV Silencer in my TT. There is no going back, the noise level is greatly reduced and as mentioned above the airflow at the ducts is far better.
2018 Rockwood Ultra Light 2304DS, 2018 Ram 2500 4x4 Cummins
RobbieH is online now   Reply With Quote
Old 07-15-2024, 04:39 PM   #10
Rhumblefish's Avatar
Down to either the RV Airflow insert box or the KoolRV duct over here. Price is *much better* on the KoolRV product, but both seem to be a lot of money for what they are (vs what they do). I can see some more potential noise reduction for both, though maybe a *little* more from the RV Airflow solution. Savings codes a-plenty were easy to find on the RV Airflow box, not so much on the KoolRV duct. More to come.
2022 Rockwood Roo 235S
15kBTU AC; 12v fridge; 1kW roof-mounted solar panels; 80 amp MPPT charge controller; 3,500w pure sine wave inverter; 30a automatic transfer switch; MicroAir EasyStart, 600ah Chins LiFePo; Honda EU2200i (with Hutch Mountain propane conversion kit) gathering dust in the storage unit.
Rhumblefish is online now   Reply With Quote
show, shower
