05-03-2018, 10:08 AM
Screw Hole Cap/Cover ??
I'm not sure where to post this question.
I am taking off a regular 8" exterior handle ( similar to this) at our rear door to our 5'r...and replacing it with a larger foldout handle ( this one).
This will match what we have at the main door.
I'd like to cover up the holes of the old handle with more than just filling them with a caulk. Does anyone have any recommendations?
I'm thinking like a cover-plate you use in your house for an electrical outlet.
Luke & Carolyn
2012 Cedar Creek Silverback 35QB4
2013 Sierra 3500HD Duramax CC SRW SB 4x4
Andersen Ultimate Aluminum 2 Gooseneck Mount
05-03-2018, 10:20 AM
Location: Alberta - East of the Rockies, West of the Rest
The screw holes are there, period.
You could counter sink a flathead screw and cap it, just use clear silicon as sealer for the screw and adhesive for the cap.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
05-03-2018, 10:22 AM
Like this
Ordered: 2021....
05-03-2018, 10:50 AM
You could always fill it with a silicone and then smooth it out and place some sort of decal over it.
2018 Rockwood 2906WS
2015 GMC Sierra
1967 Beautiful Wife
05-03-2018, 11:11 AM
Always Learning
That's very likely what I'd do.
05-03-2018, 01:17 PM
Dobbs from WI
Why not leave the original hand hold in place? Covers the screw holes perfectly. Just mount the new handle upper bracket a couple inches above the current handle. The old handle will be there for when you are just going in to grab something. That's what I'm looking to do to our trailer soon.
05-03-2018, 02:33 PM
Nice suggestion -- I think I'll go along this route. Just gotta look at best way to countersink the screw, etc.
Luke & Carolyn
05-03-2018, 02:35 PM
I was hoping to do exactly this -- but it would mean the new handle would be much higher than the one at the main door. They should be at the same height as us and kids get accustomed to reaching for it without looking etc...
Luke & Carolyn
05-03-2018, 02:48 PM
Filling screw hole
I replaced my short handle with a longer folding type. I took a couple of black #8 screws that I removed from the old handle and put dicor sealer on threads and screwed them in old holes.
05-03-2018, 04:12 PM
You need a countersink that matches the angle of the screw head or you could grind a drill bit to the right angle, but IME the drill bit catches to fast and you could end up with a giant hole instead. Whatever you do take it easy.
Ordered: 2021....
05-04-2018, 07:37 AM
I looked closer last night -- there is a good amount of the caulk/dicor(?) around each hole. So I'll need to figure out getting that off.
What is the best way as I don't want to be using a scraper on the fiberglass...scratching it and all.
Luke & Carolyn
05-04-2018, 08:19 AM
You can try any of the products below, but please test them in an inconspicuous area first.
Mineral Spirits, Rubbing Alcohol, Kerosene.
I would avoid Lacquer Thinner and Acetone.
Ordered: 2021....
05-04-2018, 07:29 PM
Go to your local autoparts store and look through their selection of trim rivets and you should be able to find some that will plug the holes and leave a small button over them.
If you can't find any the right color, you can paint them with plastic paint.
Gotta go campin!
