Old 04-24-2020, 06:40 AM   #1
Should I seal inside fan vent clips?
Climbed up on my 192 this week. Everything looked good.
One question: I notice there was no Dicor inside the clips around my fan vent. Seems like this would be an entry point for water, especially under snowpack.
Should I add a little Dicor in there, or will that muck up something else?
Thanks!
markp99 is offline   Reply With Quote
Old 04-24-2020, 06:52 AM   #2
Depends if the Vent was "Bedded Down" in a sealant when installed! If it was just a perimeter seal job you would also need to seal around the fasteners as well as the Holes you are referring to! Good Catch! Do you also have the Covers and Clips? Youroo!!
Old 04-24-2020, 07:21 AM   #3
Thanks,
Good point on whether the vent was bedded down in sealant. Who knows, right?
I think I'll add just enough Dicor in those gaps to "encourage" any water to drain away, but not interfere with the cover clips. Looking at the pour pattern, it almost looks like they intentionally avoided the clips - which was part of my question, I guess.
Vent cover is on my list.
Old 04-24-2020, 09:27 AM   #4
Bill and Gail's Avatar
There should be putty tape under the vent ridge. The clips are for the Maxxair vent cover, it's set over and held in place with hairpin style clips, which go thru those loops.
Bill and Gail is online now   Reply With Quote
Old 04-24-2020, 07:15 PM   #5
SailorSam20500's Avatar
Since it looks like you don't have the vent cover, I'll recommend that you consider getting them. With the vent cover, you can leave your vents opened a bit almost full time. Keeps rain out even in heavy rains. Also keeps air flowing and avoids mustiness.
Al
Save the Earth. Itís the only known planet with Beer.
When everything is coming your way, you're in the wrong lane.
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 04-24-2020, 07:47 PM   #6
Doppleganger's Avatar
Yea, get the cover for it. Get with the "in" crowd! I had sealant around the tabs on our 1400 dometic vent, and since the 1400 covers are unobtanium, I just drilled holes in the 1500 cover for the plastic rivets. I had to dig away some sealant around my tabs, but otherwise it installed well. It's nice not having to drill more holes in the vent to add a cover.
2016 Jeep Grand Cherokee Overland 5.7
2020 Coachman Apex Nano 187RB Outfitter & Off-Grid
Doppleganger is offline   Reply With Quote
Old 04-25-2020, 08:20 AM   #7
I agree with above, get the cover. Just remember to place it facing the proper direction. Just had to mention that after seeing one of my friends install his after a BBQ and beer.....
Greg 'n Deb
2020 R-POD 195 HRE
'17 Tacoma 3.5L,'07 Tundra 5.7L w/ tow pkgs.
Dirt Sifter is offline   Reply With Quote
fan, seal, vent
