Originally Posted by FirstFiver
What's on the other side of that square head screw? Anything?
If not, it appears there was some sort of metal piece that the square head screw was holding in place and spanned that notch in the track. Then it broke off and your rollers drops out in that spot.
Nothing behind the hex screw. It is self-tapping and screws directly into the thin metal that makes up the roller guide.
If I remove that screw and the bracket the bracket has an obvious break that is sheer to a sharp point.
That seems to be the spot where the rollers pop out of the track and I would assume that those brackets held the wheels in.
I have a couple of ideas on getting something in there. I was just hoping someone had a picture of the working units for reference.
