Old 04-28-2020, 07:30 PM   #1
DELI MAN
Slide out & AC not working
I have a 2014 FR Blue Ridge 5th wheel. I am plugged in to a 50amp service at my house. Slide nor AC is working. Fuses are okay and breakers are not tripped. Help please.
Mitch
star52656 is offline   Reply With Quote
Old 04-28-2020, 07:35 PM   #2
A32Deuce's Avatar
Slide out and thermostat should be 12 volt as far as I know. Mine are. So someplace its not working. Do lights work. RV reefer, is that working? Check battery and converter to start.
A32Deuce is offline   Reply With Quote
Old 04-28-2020, 10:35 PM   #3
bikendan's Avatar
Yep, slideout is 12v battery powered, while the a/c is 120v AC powered.
Two separate electrical systems.
Old 04-28-2020, 11:09 PM   #4
Hi, welcome to the forum from the Space Coast of Florida...
You say plugged into 50 amps. RV 50amps, not a dryer 30amp..right.
2016 Siverback 33IK, Towed 40K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
Old 04-29-2020, 10:58 AM   #5
A32Deuce's Avatar
But the thermostat is 12 volt and if that's not working that A/C won't work.
Old 04-29-2020, 03:35 PM   #6
DELI MAN
Thanks to all of you. Turned out that I had the battery disconnect on.
Old 04-29-2020, 03:47 PM   #7
bikendan's Avatar
Glad you found the problem.
Sometimes it's the basic thing.
Old 04-29-2020, 05:16 PM   #8
A32Deuce's Avatar
X2!
slide, slide out
