Originally Posted by stilmovn
My owner's manual is very specific about using no lubrication. Does that mean the original seals were too wide, and it was an installation error? Unfortunately I am out of warranty.
I believe the info your manual was referring to is not to lube the slide tracks or rails. most manuf. of slides will caution you not to lube the slide rails or tracks as that can attract dirt.
Now as far as your seals go, you SHOULD treat them on a regular basis, several times a year. Their made from rubber and vinyl, and if not treated, will dry out.
Many product out there to treat seals. You do not want to use ANYTHING with a petroleum base, such as silicon.
Use something speciffically formulated for rubber and vinyl. Many of us use a product called 303 Protectant. It Was developed only to treat/preserve rubber/vinyl.
But, anything you may use is better than not treating.
Grumpy
