Old 03-18-2018, 03:43 PM   #1
Slide outs!!!
Hello I have a 2012 lacrosse 318 bhs and the slide outs will not work unless my battery is charged even though it is plugged in to shore power.
Dylan14335 is offline   Reply With Quote
Old 03-18-2018, 03:51 PM   #2
That is because the slide out needs 12 volt power to operate even plugged in as you see will not work so you need to make sure your battery is charged. I shut my 12 volt power off in storage so not to drain down.
2017 River Stone Legacy 38mb
2001 Kenworth T2000
2016 Smart for Two on deck
dblr is offline   Reply With Quote
Old 03-18-2018, 03:55 PM   #3
But shouldn't it charge my battery once plugged into shore power
Old 03-18-2018, 04:02 PM   #4
Why does my power awning still work with battery unhooked but plugged into shore power
Old 03-18-2018, 04:03 PM   #5
Witch Doctor's Avatar
Sounds like you need to check your converter, if it not working on shore power and it can t keep your battery charged even, then you have a converter problem, could be a fuse.
Sent from my SM-N920V using Forest River Forums mobile app
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-18-2018, 04:05 PM   #6
I have checked all fuses what else do I need to check on the converter
Old 03-18-2018, 04:06 PM   #7
Your converter should be able to run all 12 volt slides and thing without even a battery, there is a test procedure in our library, if you can't find it let me know I'll post it again
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-18-2018, 04:09 PM   #8
How old is your battery? Might be hindering your system.
2001 Kenworth T2000
Old 03-18-2018, 04:12 PM   #9
Can you repost it plz.
Old 03-18-2018, 04:14 PM   #10
Battery is only a few months old
Old 03-18-2018, 05:36 PM   #11
Just as confused as you
Scrapper's Avatar
Your slide outs use more amps than the converter can supply so it needs the extra amperage the battery can supply.
Yes, but only if the reverse polarity fuses are good, the battery disconnect switch is on, and the breaker between the battery and trailer is not tripped.
Your power awning uses considerable less amperage to run than the slide motor.
Richard & Jill
slide, slide out
