Slideout “creeping out” when retracting leveling jacks
Sandpiper with 6 point auto level and 4 slides.
This just started happening today. When I retract the slides they seem to all come all the way in. When I then retract the jacks, all of the slides creep out a little bit and I have to pull them back in.
I noticed the reservoir was a little low (slides in jacks up) so topped it off. I then checked fittings and noticed one a little loose and it had a little fluid around it. Tightened it. I’m still getting the same issues (slides creeping out) after all this.
Any suggestions? Do I have air in the system? If so how do I purge.
Sounds like you have a bad check valve. On these systems the check valve is probably part of the solenoid, so either live with it or plan on buying new solenoid valves. Personally I would just retract then close.
Hi, my name is Derek and I have just joined this site. I am having trouble with the slide out on my 2016 Rockwood Roo. It seems dead, I have checked the fuse and my batteries are fully charged. I would appreciate any help
. Thanks Derek Not sure of the best way to ask questions yet?
