Unless you support the two flexing pieces from underneath, nothing like glue will hold the sheets together as any weight on/near the crack will just separate them again.
They do make sheeting clips that hold sheets together over longer spans between bracing (often used on roofing sheeting) but they need to be installed as the sheeting goes down during assembly.
