Closed Thread
Old 04-02-2020, 11:29 AM   #1
[SOLVED] any idea what this is?
i have a sunseeker 3170 and came across this strap in my bag with manuals. Can't seem to figure out what it is. thanks!
mrosenst is offline
Old 04-02-2020, 11:37 AM   #2
wmtire's Avatar
It looks like your emergency strap for your awning
2011 Flagstaff 831 RLBSS
If I eat myself will I become twice as big?...or disappear all together?
wmtire is online now
Old 04-02-2020, 11:38 AM   #3
Mr. Dan's Avatar
That's an awning strap to pull your awning out if................
The little grayish plastic piece fits in the awning tube's slot.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 32
Mr. Dan is offline
Old 04-02-2020, 11:44 AM   #4
wmtire's Avatar
Here's a video on it:
Old 04-02-2020, 11:55 AM   #5
wmtire's Avatar
Also you can see page 3 here, which explains the strap in case of emergency (power/motor failure).
https://www.forestriverforums.com/fo...?do=file&id=14
If you have a manual on your awning, it may show same.
Old 04-02-2020, 02:52 PM   #6
rockfossilman's Avatar
X2 and I hope I never have to use it!🙄
Rockfossilman - Western PA
Rockwood UL 2604ws - 2013 F150 w/MaxTow
"I'm a man, but I can change, if I have to. . .I guess."
Red Green
"Quando Omni Flunkus Moritati"
rockfossilman is online now
Old 04-02-2020, 03:03 PM   #7
Yup what they said it is an awning strap. Put it in place now in case you need it later.
campers302 is offline
Old 04-03-2020, 10:43 AM   #8
Wolverine 1945's Avatar
FROG Members Nail it again !!!
Wolverine 1945 is offline
Old 04-03-2020, 10:45 AM   #9
Install it it the middle of the roller and leave it there.
cavie is offline
Old 04-03-2020, 11:02 AM   #10
And do what with it when you don't need it?
It is for emergency retract. Not ever needed under any other circumstance on an electric awning.
Days Camped: '18=51 '19=58 '20=110 '21=47
5picker is offline
Old 04-03-2020, 11:04 AM   #11
Slid it to one end, and wrap it around the frame !!!
Old 04-03-2020, 11:08 AM   #12
If you do place it in the awning for full time storage, so you know where it is when you need it, you can simply let it roll up in side the awning.
Here is its true use.
In Case Of Coach Power Failure Or To Manually
Close Awning:
Important: This procedure will require two people. When this procedure has been performed, the awning must be serviced by a Dometic Service Center or a qualified service technician before using again.
1. Slide the pull strap (provided) into the utility slot of the FRTA.
2. While one person is holding onto the pull strap, remove the screw in the top of the right top casting.
The FRTA will immediately roll in once the bolt is removed. Walk the awning to the closed position.
3. Align hole where screw was removed and replace screw into top casting to secure awning. Attached Thumbnails
Old 04-03-2020, 11:10 AM   #13
NMWildcat's Avatar
Agreed. For an electric awning, I actually don't see that you would ever need it. I've had at least three awning motor failures that I remember. I got real good at rolling it up by hand. Actually unrolled it by hand once as I was bound and determined to use my #$&# awning whether the motor worked or not!
Can't see that the strap would of been any use at all. There was never enough recoil in the awning to even start rolling itself up. But it's still in the RV. Guess I could give it to a dog walker
Scott and Liz - Southern NM
NMWildcat is offline
Old 04-03-2020, 11:12 AM   #14
So that when you hurriedly go inside because it's a bit windy and press the switch it creates havoc by winding up and bending the arm?
On a MANUAL awning... yes, because you need it to retract/extend.
Never needed on an ELECTRIC awning unless an emergency retract is necessary.
5picker is offline
Old 04-04-2020, 10:18 AM   #15
Awning strap
Its the strap to pull down your awning. You put it in the track when winding up your awning and the strap should hang down enough to grab and pull out the awning after flipping the toggle thing on the end of the awning
TGO Bill is offline
Old 04-04-2020, 10:27 AM   #16
Mr. Dan's Avatar
The original question has been answered to death... and the OP hasn't logged in since the thread was initiated.
Thread is now CLOSED.
Mr. Dan is offline
Closed Thread
