Old 05-04-2020, 03:48 PM   #61
A32Deuce's Avatar
Originally Posted by NJKris View Post
despite a meticulous air purge, the pump strainer remains full, even after bumping pump several times to make sure the pump is empty.
That means water is still in the tank. When I tilted mine, I could not believe how much more water came out. When I put it back to level and ran the pump, all was empty. Strainer and pump.
A32Deuce is offline   Reply With Quote
Old 05-04-2020, 03:54 PM   #62
B and B's Avatar
Is it like Bubbles blowing the water back?
Old 05-04-2020, 03:59 PM   #63
Trailer Park Supervisor
NJKris's Avatar
Interesting. My tank has a slightly sloping bottom and a 'low point' built into it where the drain valve is. I think the hose from the tank to the pump is attached to same area. After draining tank and running pump, nothing was coming out of faucets. Perhaps since it could not develop pressure, water was running back out of pump into strainer? Once most of the water is out of the pump, it will no longer have much suction, as it is no longer primed. I didn't run my pump as long as you did though, as I was afraid of running it dry might damage it.
NJKris is offline   Reply With Quote
winterize, newbie, winter
