03-08-2018, 06:45 PM
#21
Originally Posted by grumpy0374
Go into any Lowes/Home Depot, plumbing section.
Ask for 1/2 inch pex. An 8 foot piece is just a few bucks. Cut it into some 2 ft sections.
Ask for some "push on" or "gator" or "sharkbite" type 1/2 inch fittings. Both streight and 90 degree. Will allow you to fix most leaks or bad fittings. Everything probably won't cost more than 15 bucks, but invalvuable if your on the road somewhere and need em.
Grumpy
Thank you very much grumpy0374, that I will do great idea to add.
Coachmen M/H
Concord
2018 / 300 DSC
03-08-2018, 06:47 PM
#22
Originally Posted by howellma
Studs? 4 bearings and seal sets I have, never thought of studs, even though I lost some when I was a teenager, was stranded out of town. Good idea, will put it on my list with some lug nuts
Oh yes, I also got the correct lug nuts to go along, cheap insurance.
Coachmen M/H
Concord
2018 / 300 DSC
03-08-2018, 06:50 PM
#23
I always carry a pre-made tool kit that came in a nice blow-molded case. Includes a good set of combination wrenches, sockets, ratchets, many driver bits. I supplement with a few extra screwdrivers and adjustable wrenches carried in a Harbor Freight plastic ammo box. Also a 12 volt air compressor and tire gauge.
03-08-2018, 07:42 PM
#24
I think I carry all the above! But, there is one I have learned to never leave home without: spare propane regulator! I've had three fail in three years...and always at the worst time.
2018 Berkshire 38A
03-08-2018, 10:08 PM
#25
Beer
03-08-2018, 10:11 PM
#26
Originally Posted by spock123
Beer
That's assumed.
03-08-2018, 10:17 PM
#27
I carry an extra slide motor and hope to never need it.
2015 Solera 24r
2017 Jeep Wrangler
03-08-2018, 10:20 PM
#28
Beer
Best answer! With enough beer, anything that is busted is just not that big a deal
I used to try and carry parts I thought I might need. Never used any of it. Just hauled it around and moved it out of the way so I could get to other stuff
All I really carry now is tools, fuses, silicon and dicor caulk, and duct tape. Really no spare parts at all. Rarely do we find we are more than an hour away from somewhere we can buy what we need. No more extras.... We are free! Free at last
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
03-08-2018, 10:34 PM
#29
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
03-08-2018, 11:32 PM
#30
Location: Alberta - East of the Rockies, West of the Rest
I do carry more but these are the tools/parts that I have actually used.
Portable air compressor, tire chuck, tire gauge, bottle jack, wood block, tire repair/patch kit, breaker bar, torque wrench, grease gun, 1/2" Pex pipe, Pex fittings, Pex crimper, plumbers tape, gas tape, LPG pressure regulator, multimeter, wire nuts, 12 Volt fuses, electrical tape, duct tape, zip ties, Dicor, caulking gun, 12 Volt drill with drill bits and screw driver bits, selection of wood screws and pocket hole screws,Lithium grease, hose washers, first aid kit, toolbox containing wrenches, socket set, pliers, cutters, hammer, tape measure, pry bar, screw drivers, allen wrenches (metric and imperial), ...
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
03-09-2018, 09:27 AM
#31
I carry a square point bit for RV style screws. Can't get anything tight or loose without it. Duct tape, electrical crimp connectors, black tape, silicone, multi meter, wire strippers, wrenches, pliers, channel locks, dikes. Figure what I can't fix with that stuff can wait till I get to the store. Not invasive as far as the space it takes up. You'll never anticipate every failure so just do proper checks and maintenance before the trip, and during the trip, and after the trip, and most situations can be dealt with ahead of time. Don't wait till your camped out to see why the furnace won't run, or the water heater won't light, or the slide motor runs slow, or the batteries won't charge.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
03-09-2018, 11:17 AM
#32
As is generally the case, these types of questions get you a broad spectrum of answers, seemly dependent on one issue or another that has been encountered while on the road. None are bad answers, it just depends on how much room you have.
03-10-2018, 09:25 PM
#33
I once had the propane hoses leak at the swivel, emptied the tanks. Wondered why the fridge was warm when I got to cades cove, ordered new ones, through a quirk in shipping I have two extra now. I have replaced both hoses now on a 5 year old camper
03-12-2018, 11:12 PM
#34
I keep in the trailer
Multimeter
Fuses of every size in the trailer.
Assortment of batteries
Basic tools
Roll of 12 gauge wire, butt connectors and crimping tool
Water hose gaskets
Blind holders
Command strips for hooks
Duct tape, zip ties. Electrical tape.
Equalizer hitch grease , hitch pin, and the L pins for the bars.
03-12-2018, 11:43 PM
#35
I had to replace mine on day4 of my new camper. Did not leak during PDI but when I got home they did. Rather than pay $40 in fuel towing the trailer into the dealer I did it myself for $12.
03-14-2018, 07:59 AM
#36
Seems as if the hoses set into the shape they are in while connected to the tank and when changing tanks any pressure on the fittings seem to cause leaks at the swivels,,,,,guess I need to look for some wire braided hoses. Need to do thorough leak test every time you change a tank.
03-21-2018, 07:31 PM
#37
I saw a couple folks mentioned bearings & seals - can you determine size/part number you need without tearing down a wheel?
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Only one shedding mutt now RIP Yoshi
03-21-2018, 07:52 PM
#38
The axle should have markings on it, the axle makers web site has all the data for the hubs
03-21-2018, 09:10 PM
#39
Thanks, I'll go take a look!
'11 F150 5.0
03-21-2018, 09:12 PM
#40
Then E-Trailer should have all the parts you need
