Old 03-10-2020, 10:50 PM   #1
Spongy floor fix
I know Rockwood constructed floors with Styrofoam sandwiched between two thin layers of luan and the floor becomes soft in spots due to this construction. I have several spots in high traffic areas in the floor of my 2016 Windjammer. I curse Forest River every time I walk on these spots. Has anybody come up with a way to reinforce these areas so they're not so spongy when trod upon?
2016 Rockwood Windjammer 3001W
2016 F150 SCREW 3.5 EB
ProPride 3P 1400
Oafdawg is offline   Reply With Quote
Old 03-16-2020, 07:38 PM   #2
hillsvillehokie's Avatar
I laid 1/8 sheet of metal over my affected area. I had a 2 foot by 3 foot piece and it works great.
hillsvillehokie is offline   Reply With Quote
Old 03-16-2020, 07:39 PM   #3
Ofcourse I put a rug over it.
Old 03-19-2020, 11:18 AM   #4
I just had the opportunity to purchase a 2014 Windjammer with the same issues. The dealer actually dropped the bottom insulation and added more cross members to help. In this case that didn't get rid of the problem but ensured it wouldn't get any worse. The problem appears to be a bad glue between the luan and the insulation. A gap occurs that gives some spring to the floor.
Our 2011 does not have any soft spots. I did have some damage from a poorly designed Thetford toilet. I removed the damaged luan and replaced with new. Problem solved.
KKonyha is offline   Reply With Quote
floor
