Old 05-25-2017, 08:16 AM   #1
Captain America's Avatar
Spun wheel stud in hub!! My LUCK!!
After dealing with a cap spinning on a lug, I decided to replace all capped lugs with solid lugs. I was taking one lug off at a time and replacing with a solid lug and then torque all lugs.
2nd to last lug, I put the impact on and the lug started to spin easily. Crap, another cap spinning on lug, NOT! The lug was cross threaded and the stud is spinning in the hub. Can't get the tire off.
Once I get the tire off, I can take hub off and replace stud. I tried pulling tire against lug to try and put pressure on stud, but still spins. I wish I could just break the stud off. I guess my next step is drilling out the stud to weaken and break it off.
THOUGHTS?????
We using RV this weekend (short mile trip) so I am not going to work on it till we get back Monday. I need to get it repaired before we go on long mile trip in June.
2018 Refection 311BHS
2011 Wildcat 32QBT (SOLD)
2006 GMC 2500, Airsafe 20K hitch, Air Lift Loadlifter 5000 air bags with Air Lift WirelessONE compressor, EFI Live
Jack of all trades, Master on none
Captain America is offline   Reply With Quote
Old 05-25-2017, 08:23 AM   #2
DAISY BOYKIN's Avatar
CUT OFF
Use a Dremel tool to split nut on two opposite sides, use a cutting disk on tool! Or a nut splitter from Auto Zone.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2019 41 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 05-25-2017, 08:29 AM   #3
jeff64's Avatar
That sucks! Don't think trying to break stud off will be successful. I'd be looking to see if I could cut the lug nut off like with a die grinder and carbide burr. Moreso, even a dremel type tool with either the wafer cut-off discs or I've seen carbide burr sets with 1/8" shanks on amazon that might get in there without screwing up your rim. I think a trip to harbor freight is in your future.
eBoTrade 20PC HSS Routing Router Bits Burr Rotary Tools Suit Dremel & Rotary Tool, Engraving, Wood Working Tools@amazon
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 05-25-2017, 08:31 AM   #4
Attachment 138999
THOUGHTS?????
In order to "Drill it out" you still have to prevent the Stud from spinning! Removal of the Axlel Nut and welding a steel Arm to the back side of stud might be the easiest way to prevent the Stud from turning!Then you could use the Impact agin! Youroo!!
Old 05-25-2017, 08:41 AM   #5
KyDan's Avatar
Bummer! It's gonna be hard to get a cut off tool in there without hitting
the wheel. I'd still try a burr tool on a dremel or air powered die grinder.
Harbor Freight fer sure.....
Youroo has the ultimate final solution if the above don't sound good to you.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41
Old 05-25-2017, 08:45 AM   #6
jeff64's Avatar
If you didn't have that "hubcap" insert in there, you could have pulled the bearing buddy , took off the spindle nut and pulled the whole works as an assembly like Youroo said. You probably won't be able to do that unless you cut that cap off
14K Equalizer
Old 05-25-2017, 08:46 AM   #7
wmtire's Avatar
Aaron, did the lugnut unscrew any before it seized on the stud?
The reason I ask is we usually can take a short handled sledge hammer and actually snap the stud, by beating on the lugnut.
But if the lugnut is still seated pretty much up in the wheel, then this is not going to be feasible, and you could damage the wheel.
2011 Flagstaff 831 RLBSS
I often say to myself, "I can't believe that cloning machine worked."
Old 05-25-2017, 08:59 AM   #8
A32Deuce's Avatar
Just pull the hub, then you can get at the back of the stud and grind, cut an x on it and snap pieces with a cold chisel. He'd to do that in the past. Easy if you have the tools.
A32Deuce is offline   Reply With Quote
Old 05-25-2017, 09:01 AM   #9
A32Deuce's Avatar
You will have to get another cap.
Old 05-25-2017, 09:36 AM   #10
Broken Toe
Cowracer's Avatar
Remove all the other studs, work a prybar in behind the wheel and force the wheel outwards to pull the stud tight against the hub. Hopefully the increased friction will be enough to hold the stud while you remove the nut. I've done this before and there is a 50-50 chance that it will work.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 05-25-2017, 10:55 AM   #11
Thanks for the tips!
I don't think there is enough lug exposed for a nut splitter. There is about 3/8" play front to back on stud, so lug has few threads on stud.
I can't get a prybar between wheel and hub. I can take hub off, but I will have to cut plastic cap to access the axle nut (last resort).
I'm going to attempt to drill it out. I will hold lug with vise grips and drill center of stud past lug, that should weaken stud to break off. Then remove hub and replace stud and repack bearings.
I'll let everyone know what method works, if this happens to someone else. I'm glad I found this in the driveway and not in BFE with a blowout.
Old 05-25-2017, 12:47 PM   #12
Sacrifice the center cap. Cut the end off. Take the drum nut off, and then you can remove the entire assembly, and then you can either cut the head of the stud off, or, if you're lucky, you can get a grip on it and hold it. Chances are if the nut is seized, you won't have that. ALSO remember that the loose stud has damaged the bore in the hub that it was pressed into, and a new one will not be tight enough. You may need to have the new stud spot welded in place. Wishing you good luck!
David and Vicki
9 year old Springer rescue Sydney
2018 Silverado LTZ 3500HD Dually Crew Cab Duramax/Allison stock "Polar Bear"
2019 Grand Design Reflection 337RLS "The Dog House II"
Andersen Ultimate 5th wheel hitch
EezTire TPMS
Springerdad is offline   Reply With Quote
Old 05-25-2017, 12:50 PM   #13
A32Deuce's Avatar
They do sell studs that are over size in the SPLINE/SWEDGE area. Good NAPA store should be able to help.
Old 05-25-2017, 01:05 PM   #14
jeff64's Avatar
Do check into the price of a new brake drum on etrailer first before you go oversize on studs or welding stuff. I'm thinking a drum might be in the $50 range. Nice to at least have a number in your head 1st
14K Equalizer
Old 05-25-2017, 02:15 PM   #15
x2 jeff54
palmetto rogue is offline   Reply With Quote
Old 05-25-2017, 05:28 PM   #16
Too old to be too smart
SpringerPop's Avatar
Yup. That situation isn't an easy one to fix.
Guess it goes without saying to NEVER put a lug nut ON with an impact.
Off, sure!
On, never!
Oh, and good practice is to start all the nuts by hand. Since you're not going to be using an impact, that's now a given.
Upon getting a new rig, I use a die on all the studs, and run a tap through all the nuts. They are usually 1/2" x 20 threads. It makes things so much easier for the entire time I own the rig.
I do that to our cars, too, though those are almost always metric threads.
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 05-25-2017, 06:42 PM   #17
I always use anti-seize on my studs before putting the lug nuts back on. Stops a lot of the issues with galling of threads that happens. Rarely have issues when I do.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 05-25-2017, 06:45 PM   #18
I agree 100% with ya Pop! I never impact a lug on. Always start by hand and then spin them on. Use torque wrench to tighten.
I bought the camper used and pervious owner said he recently had brakes checked and bearings packed. I sure that's when it was cross threaded and impacted on.
I love fixing other's screw ups! Lol
Old 05-25-2017, 06:47 PM   #19
Also, I'm glad I changed all the capped lugs, noticed two caps were split. That would of been future headaches.
Old 05-26-2017, 04:38 AM   #20
DouglasReid's Avatar
The black plastic cover over the hub will be easy to cut off. Once that is done you can remove the dust cover of the hub, take the axle nut off and remove the hub. Now you will have access to the stud from inside the hub. a mini-grinder should make short work of the stud on the back so it will come off easily.
You will need to get a new plastic hub cover, but they are cheap, especially compared to a new wheel should you damage it using one of the other proposed solutions.
btw, I replaced all my lug nuts with solid ones after finding one split and having a hell of a time getting it off. If I were on the side of the road with only the tools available in my truck it would have never happened. You made a GOOD decision to replace them. Imagine if you had found this problem too, while on the side of the road. Be thankful you are taking care of it now!
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
wheel
