Old 12-07-2017, 06:50 PM   #1
Stablizing Jacks Switch doesn't work
I have a 2016 Salem and the electric switches for the stablizing jacks don't work. Is there a way to manually extend and retract them? My remote still works, but I would like to know I can operate them without power.
Wayne Hemmerich is offline   Reply With Quote
Old 12-07-2017, 07:00 PM   #2
Yes, on the opposite end from the motor. I would pull the switch and check and make sure you have 12v to the switch. Switches do go bad and connections come loose.
Old 12-07-2017, 07:26 PM   #3
Thank Coot.
Old 12-08-2017, 07:54 AM   #4
Both of mine quit within a month of each other on my Heritage Glen 299RE. Called Lippert and they mailed me a new one, free of charge. Dealer replaced second one, also free. New design on new ones.
MartyNH is offline   Reply With Quote
Old 12-08-2017, 08:23 AM   #5
If your remote still works the stabs, it sounds like a switch problem.
As OC said, pull the switch and check for voltage.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 12-08-2017, 09:05 AM   #6
Handyman
Dealer replaced both of mine. They said all the original switches caused problems. I've had new switches for a year with no problems.
Link to owner's manual: https://www.lci1.com/assets/content/...ers_Manual.pdf
2016 Salem Cruise Lite 253RLXL
2013 F-150 XLT 5.0 Crew Cab
2009 F-150 King Ranch 5.4 Crew Cab
tfmdgm is offline   Reply With Quote
Old 12-08-2017, 11:11 AM   #7
Thanks for the info
Old 12-08-2017, 11:16 AM   #8
Will do. Thanks
Old 12-08-2017, 02:24 PM   #9
Retiredtwo's Avatar
Sabilizer Jacks
Our rear one went out twice, dealer fixed and found the connector from switch to the motor had come loose. We used the handle that came with to lower and raise on our 3 week trip. I had read that could back feed the board and cause trouble but it didn't.
Robert&Carol
17' Ram Big Horn 1500 quad cab
Wildwood 171 RBXL
Retiredtwo is offline   Reply With Quote
Old 12-08-2017, 02:34 PM   #10
Powerless Stabilizer Jacks
My 2014 Wildwood came with a crank for the jacks, and another for the slide. On one occasion, I had to use the stabilizer crank. For some reason the switch didn't work. But the crank worked just fine.
JimMorrell is offline   Reply With Quote
Old 12-08-2017, 06:04 PM   #11
Bene Gesserit Rule
Murbella7's Avatar
My 2015 Wildwood also has a handle for manually winding jacks and slideouts, been used a few times too, when batteries die. The DPDT switch used on the front jacks and rear stabilisers can be replaced easily with a unit you can get at a Radio Shack type store (or online). A lot cheaper than paying a techo to do the work, and you learn a little more about that big expensive maintenance nightmare (but fun home-from-home) thing you bought.
Murbella7 is offline   Reply With Quote
jacks, switch
