05-03-2020, 08:40 PM
Strange smell!
A little delicate subject, a bit stinky! I am getting a very strong, pungent smell from the bathroom. The blank tank has been cleaned thoroughly, three times and doesn't seem to be coming from the tank. Did the smell test close to toilet opening to confirm. The smell is like strong urine, chemical like. Have checked everywhere, even under the belly. Can't seem to find anything that would cause this. Any ideas?
05-03-2020, 08:53 PM
It could be that the toilet is leaking. These toilets have a plastic ring (like the wax ring in a home toilet) that can go bad and cause a leak at the base.
2015 Dynamax REV 24TB class C
05-03-2020, 09:03 PM
Thought I read about some toilets have a defect and will trap waste water in them, not sure the model tho. A quick search may help
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 2
05-03-2020, 09:09 PM
Scoundrel
Also you may want to look for an anti-siphon trap vent under the bathroom sink. When they go bad it can stink up the place. Replacement is an easy fix.
https://www.loveyourrv.com/bad-smell-coming-rv-sink/
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
05-03-2020, 09:30 PM
It is probably your toilet. There have been many threads about the Dometic Model 300 toilet. They have a defect where liquids (urine water) gets trapped between the bowl and the base.
Look on the side of your toilet by the flush pedal and get the make, model number, serial number (use your phone camera). If it is a model 300, call Dometic and see if it is one in the recall.
2016 Siverback 33IK, Towed 40K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
05-04-2020, 05:53 PM
Do this ^. You probably have the Dometic 300 that has a seal between the top and bottom half that fails and allows urine and water to collect. Sometimes you can squeeze phone camera along the back and see the issue. Here’s a pic of what it might look like.
TT: Flagstaff 25FBLS
Previous TT: Jayco, Rockwood and Flagstaff
TV: 2017 F-150 SCREW, 3.5L Ecoboost, 10 speed, 3.55, 7000# GVWR, tow package.
05-04-2020, 06:07 PM
X2 Dometic 300. If that is what you have, contact Dometic.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
05-06-2020, 10:33 AM
Thanks everyone! Problem solved. Did have a 300 series toilet, bought a new one and replaced. Now will try and deal with Dometic. I was concerned with the new toilet having the same problem but the reviews were pretty good and the sell person assured us of quality, so we replaced it with a Dometic 320 unit. Installation took 15 minutes! One and done, hopefully!
05-06-2020, 10:35 AM
Originally Posted by Funengineer
Do this ^. You probably have the Dometic 300 that has a seal between the top and bottom half that fails and allows urine and water to collect. Sometimes you can squeeze phone camera along the back and see the issue. Here’s a pic of what it might look like. Attachment 228379
That is one scary picture! Wow!
05-06-2020, 11:15 AM
Good choice on the 320. An actual ‘adult’ toilet.
05-10-2020, 07:11 PM
Can just the seal be replaced or must the entire toilet be replaced? We have a 3 year old unit.
05-10-2020, 07:32 PM
Just as confused as you
I had read somewhere that the Dometic 300 toilet can not be disassembled and the seal replaced. I believe it was in the owners manual someone posted here in the forums.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
05-10-2020, 07:54 PM
Thanks.
05-14-2020, 09:45 AM
I just spoke with Dometic sanitation division 800-321-9886 I also have a 300 model toilet experiencing this smell. They are not referring to it as a recall but were very nice on the phone. They offered me an upgrade to the 310 model for $50 and $75 for the 310 with a slow close lid. I have not measured the rough in space but she said you need 9&5/8" from center drain to the back wall for the 310 to fit.
2020 Salem 31KQBTS
Tow Vehicle 11' 6.7 F250
