Old 03-10-2024, 10:33 AM   #21
Well I think I have resolved my furnace problem , after two wrong boards that was supposed to work in mine a new board has remedied the problem . I have become good at taking the furnace in and out ! The old board must have had a cold solder joint or bad resistor , or something as it would work fine sometimes but when it quit it did not run for several hours . At one point I had decided it was the thermostat as it stoped but was still calling for heat . But not the case , if I ever go through this again I will make myself a bench test set up and solve it out side of the camper . Hope this might help someone else and thanks gang for suggestions and interest !
Doctarie is offline   Reply With Quote
Old 03-10-2024, 10:53 AM   #22
Good job!
Originally Posted by Doctarie View Post
Well I think I have resolved my furnace problem , after two wrong boards that was supposed to work in mine a new board has remedied the problem . I have become good at taking the furnace in and out ! The old board must have had a cold solder joint or bad resistor , or something as it would work fine sometimes but when it quit it did not run for several hours . At one point I had decided it was the thermostat as it stopped but was still calling for heat . But not the case , if I ever go through this again I will make myself a bench test set up and solve it out side of the camper . Hope this might help someone else and thanks gang for suggestions and interest !
Good job!
I know what you mean about repeated removal/reinstallation. On the first one I worked on, I must have had it in and out a dozen times.
Bench testing would have not helped resolve my problem. In that case, the furnace would light and operate perfectly every time with the front plenum cover off. (That's the first cover you see after you take the return air grille off.) If that cover was on, the furnace would never light.
It turned out that the propane regulator had gone bad. I had bypassed the first troubleshooting step, test the pressure, because I didn't have a measuring tool. Finally, after wasting hours, I built a manometer--it took $5 in fittings, some scrap from my workshop, and less than an hour. I still have it.
My guess is that the furnace behavior varied with the cover off because the same motor drives the combustion impeller and the circulation impeller. Their rotational speeds must have varied due to lower air resistance with the plenum (circulation) cover off.
Larry
Larry-NC is offline   Reply With Quote
Old 03-11-2024, 07:07 AM   #23
Good to hear. Let's hope so.
I like how you properly use the word "think".
Intermittent problem and not actually finding a fault you never know for sure if your "fix" was the problem. Especially if a problem is a long time between failures.
Been there. Sometimes you do just have to shotgun it and hope for the best even though I hate doing that.
2022 Rockwood 2511S
2018 F150 3.5 Crew Cab 4x4
Max Tow Package 1855 Lbs Payload
Husky CenterLine WDH
GolfingDave is offline   Reply With Quote
Old 03-11-2024, 08:23 AM   #24
That’s exactly where I at , everytime I thought I had found the culprit it proved to not be it , to bench test would be a big help as when it had a failure it could test for power through the system . But it’s working for now !
Old 03-11-2024, 08:32 AM   #25
Glad you got it working. Thanks for coming back and following up.
Just wondering how you got two wrong boards and then one that remedied the problem?
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=101
Old 03-11-2024, 09:31 AM   #26
5picker……………Amazon , first two were a pin 50 clone that were supposed to work with the sf30qf but when you plugged the harness to the board the blower ran all the time .amazon replaced the first with one just like it same results so went a different route
furnace, suburban
