Old 12-08-2015, 11:04 AM   #1
Sunseeker Tail Light Bulb
I have a 2013 Sunseeker 3170DS, what bulbs are used for the tail lights, rear turn signals and running lights.
Any magic in changing these?
Thanks,
Tom
Linda
LTRVing is offline   Reply With Quote
Old 12-10-2015, 08:55 AM   #2
knockando's Avatar
I would say no magic, pop off the covers, remove the bulb, take to your local auto supply store match it up and pop it back in. I haven't needed to change turn signals yet so those might be different.
knockando is offline   Reply With Quote
Old 12-10-2015, 09:00 AM   #3
RSchleder's Avatar
What he said!!!!!! No rocket science here!!!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 12-12-2015, 08:56 AM   #4
Wandering's Avatar
Check out this thread. LED replacements are much more visible and simple to install.
http://www.forestriverforums.com/for...ad.php?t=90130
Forester 2451s
Forester 2451s
Wandering is offline   Reply With Quote
Old 12-12-2015, 09:26 AM   #5
Looks good, thank you for the info...
Tom
Linda
Old 12-12-2015, 09:59 AM   #6
If you have conventional brass base bulbs like those in our 2011 Sunseeker, you may want to add some sealer around the lenses. The fixtures have no seals. Some have reported water getting into the fixtures. Once, water got into 3 of the 4 on ours while driving in heavy rain and the water shattered the bulbs. Oddly, this only happened once even though we have driven in the rain many times. After having the bulbs shatter, I ran a small bead of black RTV around the top and sides of the base, let it set a few minutes to skin over, then put the lens back on. The RTV doesn't stick to both, so I could easily remove the lenses later. I didn't put RTV on the bottom so it wouldn't prevent condensation from draining. Some stated they just used Vaseline.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 12-12-2015, 04:22 PM   #7
Are the interior 12v LED light bulbs available at an auto supply or do I have to go to a RV dealer?
Maggiewaggie is offline   Reply With Quote
light, sunseeker
