12-17-2015, 07:57 AM
Super Strange Furnace Issue
I bought my Flagstaff 831RLBSS on Nov 4 and pulled it to Gulf State Park 3 days later. Used the furnace all month in Nov off and on occasionally. Used up one bottle of propane and it automatically switched to the other tank. Left trailer for a few days to return to Tn. Came back and when I turned the heat on the blower would come on and run a minute and shut off. I checked the propane tanks and filled the one empty one. Still no heat. Called warranty repair and they gave me 3 RV repair facilities. I called Cherokee RV and the service tech came out and checked the unit. He found that the switch on the furnace was turned off!!!!
So, how is this possible? I did not turn it off. I don't think I can even reach the switch with the init in place. I know I used the heat prior to this.
Strange things!!
2015 Flagstaff 831RBLSS
2015 Ram 2500 6.7 Cummings Crew
2014 Lowe Stinger 175
2013 FJR1300
12-17-2015, 09:02 AM
What furnace switch?
12-17-2015, 09:05 AM
I agree what furnace switch?
12-17-2015, 10:03 AM
There is a switch inside the furnace that turns the control board on and off.
12-17-2015, 10:04 AM
Suburban furnace?
12-17-2015, 10:06 AM
Suburban furnace?
Yes it is a Suburban but I do not know the model number.
12-17-2015, 10:18 AM
FM!
12-17-2015, 10:42 AM
Left Coast
Originally Posted by A32Deuce
FM!
X2
12-17-2015, 10:53 AM
Where did he access said switch?
12-17-2015, 11:24 AM
Usually on the side of the furnace......
Fonzie
12-17-2015, 11:39 AM
He pulled the unit and the switch was right inside the housing where the wires go in.
I wonder if the switch was not pushed all the way on and vibration caused it to move to the off position. No signs of a mouse..lol.
I assume this is not an overload switch?
Cost me $140.00 service call. Non warranty issue according to tech. I will discuss with my dealer!
2013 FJR1300
12-17-2015, 11:53 AM
Was this switch accessible from an outside compartment/storage area?
If so, was it locked?
If not, (accessible only from inside your camper) was it locked?
The service guy actually had to "pull the unit" to get to the switch?
12-17-2015, 12:05 PM
Left Coast
Havn't seen anything more then the intake/exhaust vent accessible from outside.....furnaces , the ones I'v seen, are installed from inside....very easy to remove.
12-17-2015, 12:14 PM
Ep, only access is from inside unit. There is a panel below the refrigerator that is screwed on with 4 Phillips screws.
2013 FJR1300
12-17-2015, 02:50 PM
Is it possible the tech hit the switch when removing the furnace? Something just does not sound right.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
12-17-2015, 03:56 PM
You want to talk about strange! I live in Northern Alberta and was pulling the 5er south with the 04 Dodge Ram3500 Cummins. Me and DW had travelled at least 250 Km and I pulled up to an intersection. When I started to pull ahead the truck hesitated a bit and I hit the brakes, maybe 10 feet into the intersection and the truck stopped. Upon failing to start after several attempts CAA was called and hauled our sorry butts off to the local Dodge dealer, 5er and all. Dodge had a look and told me the fuel pump fuse was missing. Wasn't in there, don't know where or when it went! They put in a new fuse and it hasn't stopped since.
12-17-2015, 04:10 PM
Jim
It's possible but the unit would not work when he pulled it out and it did after.
12-17-2015, 04:17 PM
Your symptoms sound like a stuck sail switch. I bet that he bumped the on/off switch when removing the unit and chalked the problem up to that. However, I suspect that removing the unit jarred the sail switch loose and that's what actually fixed the problem.
Gotta go campin!
12-17-2015, 04:48 PM
Wouldn't blower still run?
12-17-2015, 05:01 PM
The blower would run for about a minute the shut off. It may have been a stuck sail switch. Didn't think about that.
