01-31-2020, 12:04 PM
#121
Major difference between a Surge Suppressor and an Electrical Management System. Spikes are rarer compared to low voltage and mis-wired connections on a campground power pedestal. I do regret cheaping out and not getting the remote display for my install version EMS. The power inlet and EMS is under a dinette seat. I did plug in a basic $5 voltmeter display near the door where it is easily read in bed.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
01-31-2020, 12:41 PM
#122
Trailer Park Supervisor
Boomerweps, you can always get that display separately if you want, I think it's easy to install.
Yes, I drink the water!
01-31-2020, 01:43 PM
#123
EMS Protection
In my post #31, I said in all my years camping, never needed one. However I'm changing my mind. With 2 tablets controlling almost everything, a touch pad type thermostat, TVs, Radios, microwave, auto level, A/C, refrigerator and WH control boards, and on and on, The Forester is not the same as my simple 2002 TT of old. I was going to perm install an EMS, but I have read that if it is wiped out by whatever, you will have to do some unpleasant rewire work-around at your site to get anything to work again to be able to leave. So I will see if I can get at the incoming cord to install the EMS inside and plug it in to a new outlet box which would be ideal. To get stuff destroyed, the diagnostics cost, items burned out and the repair dry dock time and so forth is not worth it. All this happening on a long trip from home makes a person reconsider. Also, considering what a Forester cost, EMS cost is petty cash.
01-31-2020, 04:49 PM
#124
Originally Posted by cavie
Need more info. What are you talking about? Are you talking about surge protector power strips?? JUNK.
Yes internal surge strip. I have blown out 3 (not cheapo ones either).
01-31-2020, 05:11 PM
#125
Are these strips blowing out on the same shore power? Do they blow out on your generator?
01-31-2020, 07:31 PM
#126
The Progressive hard wired EMS has a bypass switch that will disable all functions of the EMS in the event of a failure, except for the surge protection function. I have not had a failure of the unit so as to be able to test the bypass switch.
But yes, ideally you could use a portable EMS with plugs and sockets and have it mounted in a basement storage bay. Removing it from the circuit could be easy, if desired.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
01-31-2020, 08:23 PM
#127
Originally Posted by BehindBars
The Progessive hard wired EMS has a bypass switch that will disable all functions of the EMS in the event of a failure, except for the surge protection function. I have not had a failure of the unit so as to be able to test the bypass switch.
Right. The remote display has a slide switch on it to bypass. I think the hard-wired unit with the built-in display requires you to open it up and move a jumper.
After we had several A/C shutdowns due to low voltage on our very second trip, I bought a Hughes Autoformer and installed it inside the electrical bay. The link is below for what I did and in one picture you can see the black box that is the Progressive Industries EMS hard-wired unit.
http://www.forestriverforums.com/for...er-197035.html
Ray
2020 Georgetown GT5 34H5
02-01-2020, 07:39 AM
#128
good thinking!! The EMS is like a firearm, you never know when you will wish you had one. But if that day ever comes, Nothing else will suffice
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
02-02-2020, 11:55 AM
#129
I added my PI 50 amp EMS in a space behind my power center. I used 50amp range cords and outlet so if needed I can remove the EMS and plug the power center back in. Takes seconds. Then the next summer we were at a spot that I had to use both 50 and 30 amp cords to reach the power pole at the site. Our shore power connection is at back of the trailer. So I added a second shore power inlet at the front of the trailer and a second range outlet next to the first one at the EMS and now I can reach the 50amp power with my 50 amp cord anywhere.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
02-02-2020, 12:41 PM
#130
No, you absolutely do NOT ever need one . . . . . . . until you do!!
There are three groups on this issue: (1) those that scoff at them because "in XX years of RV'ing I've never used one and never had a problem"; (2) those that swear by them because they've had an issue and had to replace a $200-300 EMS instead of $10,000+ in RV equipment/components; and (3) those that swear by them for the warm and fuzzy feeling they get.
No matter what group you fall into, it all comes down to something called the "Calculus of Risk", which is essentially: P = R x D where
P = the cost of Prevention
R = the Risk of the event, expressed in % of likelihood
D = the Damage caused
The "R" is pretty subjective, some people, like Group 1 above, think the likelihood of a catastrophic power issue is maybe 0-3%?? For Group 2, it's 100% - they've experienced it and it's only a matter of time before it happens again. For Group 3, who knows? Maybe 25%? 35%?
The "D" is the driving factor. If you have a simple, 30 year old pop up, your "D" might be $200 - replace some lights and maybe a small fridge? If you have a Class A motorhome, $10-15,000+??? Even a relatively simple but modern TT, in the case of a catastrophic power issue, you're probably looking at $2,000+?
Multiply your R by your D and compare it to your "P". (In this case, the "P" is pretty constant across the board, somewhere between $200-400, depending on the EMS, whether you want to hardwire it in, etc.)
If your "R x D" is more than your P, then buy the EMS. If not, don't.
Personally, even if I'm in Group 1, I'm buying an EMS to protect my coach (3% x $15,000 = $450, which is more than the cost of my EMS @ $275). In actuality, I'm in Group 3, so my Calculus of Risk is 25% X $15,000 = $3,750 versus the $275 spent on a quality EMS. No brainer . . .
2015 Berkshire 34QS
02-02-2020, 12:49 PM
#131
If I recall, you're the insurance guy, right?
02-02-2020, 12:51 PM
#132
2015 Berkshire 34QS
02-03-2020, 05:57 AM
#133
Which explains why that answer was clear and complete but most certainly not concise
02-03-2020, 01:17 PM
#134
Haha - paid by the word!!
2015 Berkshire 34QS
02-14-2020, 09:53 AM
#135
Shore power. No gen
02-14-2020, 10:40 AM
#136
Originally Posted by Catalina_Wine_Mixer
Hello all,
Lets talk about surge protectors. As a newbie to the TT/RV world I have questions
1. Do I need a surge protector?
2. Do you use one?
3. What do you use/recommend?
4. Why do you recommend that one?
Thanks!
Yes you need one.
Mike
Mike Gray
Forest River Wildwood
2017 27 RKSS
2015 Sierra SLE 5.3 V8 4x4
02-14-2020, 11:00 AM
#137
Why?
No, you don't need one to RV, but you might desire one
Originally Posted by Mike223
Yes you need one.
Mike
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
03-15-2020, 09:24 AM
#138
Keeping an older thread alive.
I'm looking at surge protection /ems units. I like the Progressive Industries units but have a different type of question.
Our current travel trailer is a 2014 Salem 30 Amp unit. We always connect to 50 Amp service due to being a better solid 30 Amp service with fewer interruptions using a dogbone adapter. My question is can I use a 50 Amp ems or surge protector for a 30 Amp TT? I know amps and voltage are two different things but I'm more concerned with the PI 50 Amp ems!/surge protector reading correctly as far as warnings and such. Thanks
PS.. The reason I'm wanting to buy a 50 Amp ems is that we've been thinking about upgrading our TT to a toy hauler and I'm sure it will be 50 Amp. So for now I'm hoping to buy a 50 Amp ems /surge protector so I only have to buy one.
03-15-2020, 09:31 AM
#139
Yes you can use a 50 amp. Just buy a portable and a 50/30 dog bone adapter.
03-15-2020, 09:43 AM
#140
info
you dont have to spend $$200 on an ev surge protector.they gave leviton whole house protectors at home depot site for $50
Save a beer for me!!! Happy Trails....Be Safe....
