Pretty much same views as above. I did put a remote thermometer in my underbelly a few times and found it to be about eight degrees warmer than ambient. Depending on wind, temperature and duration. It was about ambient near morning one time with a pretty strong wind.
Even shot my laser thermometer down the toilet with the heaters on, almost always 60 degrees or warmer. No way to tell if the others are working without taking some ammeter readings. May rig something up sometime.
Hoping to keep the dump valves from freezing and breaking I did insulate them. Still seems to be holding up even driving in a fair amount of rain.
https://www.forestriverforums.com/fo...ng-260061.html
I am going to put some tape over the underbelly to frame seam this summer just to fill up the gaps. Put foil tape on any side gaps in the frame already.
I take my hose off at the faucet any time freezing weather is close overnight. Not because 30 degrees will break the hose or faucet over a short period of time but because I already had to replace a pressure gauge when it froze.
I did have one fresh water drain valve line freeze enough to stop flow to my bathroom sink. 36 hours without getting above 25 degrees did that. Other than that low twenties do not alarm me, as long as it does warm up some during the day.
I did do this for when temps start getting into the teens.
https://www.forestriverforums.com/fo...at-259934.html
