10-29-2018, 09:51 AM
Tire questions
I am trying to determine why I had a blowout on one of my tires last night. I am wondering if Forest River uses cheap tires? My trailer is a little more than a year old and hasnt been pulled more than 500 miles yet. Last night my right rear tire developed a bulge and then blew. I am also wondering is it safe to travel any distance with only one tire on a dual axel system? I had to drive a few miles before I could find a place to pull over. I always adjust to proper air pressure before a trip with nitrogen. Has anybody else had unwarrented failures on these new tires?
10-29-2018, 10:02 AM
Sorry, that doesn't look like a tire with only 500 miles on it. What was the inflation pressure before you left on your trip?
2007 Coachman Freelander 26' w/ E-450 6.0L diesel
1982 El Dorado Bermuda 27' w/ E-350 460 gas (sold)
10-29-2018, 10:03 AM
Chances are FR used the cheapest Chinese tire they could source. Tires are probably the most discussed issue in RV forums, just search on "tires." It would help to know the brand you have.
Towing with only one tire will severely overload it and it probably should be replaced, too. No spare or road service? If you have to replace your tires, it's best to upgrade from a c-rated to d-rated, or d- to e-rated. If you do, make sure your wheels are rated for the additional psi required.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
10-29-2018, 10:07 AM
Denver To Yuma In 90 Days
Here we go...again!
10-29-2018, 10:09 AM
While what Phillyg says is somewhat true, your picture shows the tire to be severely worn for some reason. Might have had some misalignment scrubbing or some from running on it after the blow out, hard to tell.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
10-29-2018, 10:12 AM
My opinion is... that tire has been "bad" for a while. The tire appears to be worn in the blown area which to me translates to a broken belt/worn on the high spot.
These could easily be detected(when kinda) by jacking the RV up and rotating the tire and paying attention to OD of the tire and "checking for round" as you spin it.
Could easily be caused by impact on the tire...FWIW
One more thing... That "few miles" on one tire translates to a possible overload on the one tire.
2017 Puma 297RLSS
10-29-2018, 10:19 AM
I've just gotten into the habit of giving a quick glance at each tire including the treads (and touch the hubs to see if they are hot) every time I stop for gas or meals...
Only takes a few seconds and should alert to most approaching problems.
10-29-2018, 10:37 AM
I'm currently dealing with this exact same issue. Go though all of the paperwork with the camper and find the one for the tire. Call the number and file a warranty claim. Mine caused damage to the rv so I got sent to a different department. They had ups pick up all 4 tires (I had all 4 replaced) to take their engineering department so they can determine what caused the issue. They lady on the phone said she would give a good will gesture of 125 per tire so that will almost pay for the new maxis. I'm currently waiting to see what they come back with, but I'm expecting them to say it was something I did wrong and weasel out of them.
My tires were 2 years old and I was planning on replacing them this winter. I made sure they had 80 psi in them when leaving and keep it at 65 or below.
2017 Wildcat 327RE
2005 Chevy Silverado
2016 Nights camped in wildcat(14) didn't count previous trailer
2017 Nights camped (44)
2018 Nights camped (29) that's too low. Must work on it.
10-29-2018, 10:58 AM
Lower cost RVs use cheap ST tires and to my knowledge, they are all made overseas. My 2018 Cardinal 3825 came with Goodyear LT tires.
10-29-2018, 11:36 AM
Many of the "higher priced" RV's come with cheap tires, too!
