03-21-2018, 10:02 AM
#21
Originally Posted by timfromma
Not unless Florida was relocated and noone told me about it.
Maybe a great time to go hey ???
Snow Birds all headed North ???
03-21-2018, 06:42 PM
#22
Originally Posted by cavie
Kinda depends on where you live don't it. Have you looked out your window if you are on the east coast today 3/21/2008
I guess it’s a good thing I opted to hold off.
03-22-2018, 09:51 AM
#23
Looks pretty bad out East !!!
Can't say I am sorry it was not us for a change !!!
Hope all the Easteners get thru it ok !!!
03-22-2018, 10:10 AM
#24
Grammar Pedant
I de-winterize (summerize? springize?) at the very end of April or early May. I'm in Colorado where March is typically our snowiest month of the year and April goes back and forth between hot weather and snow. It doesn't take much for small, above-ground pipes to freeze. Mid-April would probably be OK for me, but I don't get to camp until mid/end of May anyway.
You can always run a few experiments. Just get some scrap pipe and put water in it. Leave it outside, ideally suspended from something (not in contact with the ground). Does the water in it freeze? Doesn't really help you right now, but you can build your knowledge for next year.
Former RV: 2018 Rockwood Mini Lite 2504S
03-22-2018, 10:20 AM
#25
There is no need to dewinterize until you want to use your RV !!!
Could be May before we get to it !!!
03-22-2018, 10:29 AM
#26
Originally Posted by Wolverine 1945
I just want to get started on my lawn !!!
But they are calling for snow this weekend !!!
Mow quick
2018 Cedar Creek Silverback 29IK
18 Silverado 3500 HD Dually 6.6 Duramax 4X4
Ultimate Aluminum 5th Wheel Hitch, TST tire monitors w/repeater
Semi-Retired February 3, 2014
Bob & Cindy
03-22-2018, 10:50 AM
#27
03-22-2018, 10:59 AM
#28
As quick as it is to dewinterize, what's the hurry anyway? I can dewinterize my Vengeance in 10 minutes. Just run fresh water through the thing, throw the anode rod into the water heater, let it fill and you're done.
03-22-2018, 11:08 AM
#29
Do you not sanitize with a little bleach ???
03-22-2018, 11:15 AM
#30
Not me. I don't drink the water, just use it for flushing & washing.
Joe
Current: 2022 Keystone Cougar 26RBS
Past: 2020 Rockwood MiniLite 2205S
Past: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
03-22-2018, 11:28 AM
#31
Still a good idea to sanitize the fresh water tank. Very small amount of bleach needed to accomplish the task and you probably already have the bleach in your laundry room.
We don't drink it either but if you wash with it the water will eventually touch your mouth at some point. If you wash vegetables with the water that's a very good way for it to occur.
Bob & Cindy
03-22-2018, 11:30 AM
#32
I think I would still sanitize !!!
But that is just me !!!
03-22-2018, 11:46 AM
#33
Grammar Pedant
In my PUP, the water system clearly hadn't been sanitized by the original owner(s). Even though we weren't wanting to drink the water, the lines and the grey water outlet stunk. Lots of biofilm had built up. It took me a lot of time and bleach to rinse that stuff out. Sanitizing might not be a bad idea even if you don't drink it. It keeps the lines healthy and free of biofilm.
Good luck.
03-22-2018, 11:47 AM
#34
I had emptied the potable tank & the water heater, and then blew it out with compressed air to winterize. So there was little if any water left before I half filled the water tank last month. If I note a funky aroma, I'll hit the tank with some Clorox.
Joe
03-22-2018, 11:50 AM
#35
I am going to have to sanitize my fresh water tank soon because the monitor is showing it full,,, it is empty !!! I am hoping sanitizing will fix the problem ???
03-22-2018, 11:55 AM
#36
I will be flushing our sys with a strong bleach solution,,, running it thru all faucets & toilet, and let it set for a couple days,,, before flushing it with fresh water !!!
03-22-2018, 12:06 PM
#37
I do this every year, My system is sitting with bleach water since Sunday.
I normally hook up a hose and spray down the awning with the same bleach water.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
03-22-2018, 12:10 PM
#38
Insert witty title here
I sanitize with this stuff:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I pour half the container into my FW tank then fill the tank the rest of the way with water. I will then use my pump to pump it throughout the camper including the water heater. I'll let sit for 24hrs before flushing again with plain water.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
03-22-2018, 12:11 PM
#39
He have a stupid Black awning,,,so I just use Murphy's soap 7 water !!!
03-22-2018, 12:25 PM
#40
I did the half bottle trick as well the first time we did it. I didn't however flush it through and refill the tank. A few days later it stung our mouths to brush our teeth, skin started itching, and my hair started turning white. Maybe just a little too much bleach. I found out that 2oz. for about 40 gals. is the right amount to use. Search the internet for the proper amount to add for your size tank. You won't be sorry.
Bob & Cindy
