Originally Posted by NavyLCDR
Hmmm. My slide-out has the dinette which seats 4 people and the refrigerator plus two storage areas under the dinette benches. I would hope they designed my slide-out to hold like 1,500 lbs.
Will probably hold 1,500 lbs while extended however:
A Refer around 115#, four people (average US Male 197#) ~800# and another couple hundred pounds of "stuff" comes to about 1200# on the extended slide.
I seriously doubt that any slide was designed to be operated with four people sitting around if for no other reason than load on the motor when being operated.
The refrigerator itself is mounted on the inboard side of the slide and only contributes a small amount of weight to the overhang.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
