Old 05-08-2021, 06:34 PM   #1
Truma water heater
Anyone have any advice on propane truma water heater.
Pulled Into Yellowstone National Park and filled my propane tank it was halfway.
Stayed at a park with full hookup The low at night was about 28゚ Park Manger suggested disconnecting the water so that their pipe did not freeze They had a separate heater on it. And the water was ice cold.
Everything was fine until the 1st morning taking a shower the water started out hot and then went to Luke warm and never recovered.
If I shut it off for about 15 seconds and then turn it back on it comes back hot but then immediately goes to lukewarm Again.
I spoke with a representative from the company Any took me through a series of troubleshooting Techniques.
To which neither gave any indication Of a problem for a solution.
The last suggestion he gave me is to have LP service man adj. The regulator to a higher pressure.
I have not done anything yet ..the coach is only 1 year old and never had this problem before.
Runner58 is offline   Reply With Quote
Old 05-09-2021, 06:21 AM   #2
How is the propane to your other devices? Does your stove work or your heater?
2017 River Stone Legacy 38mb
2001 Kenworth T2000
2008 Smart on deck
dblr is offline   Reply With Quote
Old 05-09-2021, 09:44 AM   #3
Heater and stove work great no problems...
Old 05-09-2021, 09:49 AM   #4
The stove and heater have no problems..
Old 05-09-2021, 10:37 AM   #5
Is this a tankless heater or a traditional tank heater?
I ask because tankless heaters generally need some adjustment for altitude to work properly. IIRC, Yellowstone varies from 7K to 9K ft altitude. If set for near sea level, the reduced oxygen at altitude creates less heat in the burner. With a tank no issue, the fire runs a little longer to get the water hot. Without a tank, water can't get as warm as fast unless settings are changed.
Fred W
2019 Flagstaff T21TBHW A-frame
Old 05-09-2021, 10:42 AM   #6
Truma is a tankless water heater. Just for kicks have you shut it off and turn it back on, kind of like a reset. When we have a issue that is what we do. Just thinking out loud.
2001 Kenworth T2000
2008 Smart on deck
Old 05-09-2021, 10:54 AM   #7
llamb's Avatar
Overall any tankless hot water system (even with a small recirculation tank) will have a limit of the temperature recovery based on the water source. This is all based on the number of BTUs (60K for the Truma) the device can impart on the water and how fast a flow rate. Unfortunately, I can't find any charts on the Truma for those numbers.
The Yellowstone area has some of the coldest groundwater temps in the US.
So I'd agree that if the unit isn't getting enough gas, you may want to raise the gas pressure. The other thing you can try is to restrict the flow. The later will allow more time in the heat exchanger and thus a greater temperature rise.
Larry
2021 Riverstone Legacy 42FSKG
2016 RAM 3500 DRW
llamb is offline   Reply With Quote
Old 05-09-2021, 11:08 AM   #8
What setting do you have the control knob set to? Make sure it is not on economy, on the first setting it actually kind of pre-heats the water, that way if it is real cold coming in that helps some.
2001 Kenworth T2000
2008 Smart on deck
Old 05-09-2021, 11:15 AM   #9
nomad297's Avatar
I wouldn’t expect too much out of a tankless water heater that consumes only about 60,000BTUH of gas when the incoming water temperature is as cold as it probably is where you are. I know the RV versions of these water heaters don’t have to meet the same demands of a house where two to three people may be using hot water at the same time, but the residential units I install generally require right around 200,000 BTUH to raise the temperature of the incoming water from ~50 degrees to 120 degrees. After only a year or so of use with hard water, even these residential units can get to the point where they don’t produce water hot enough for just one user. There are so many things to consider when diagnosing why a tankless water heater isn’t working like it did when it was new — even after only one year.
Bruce
Old 05-09-2021, 11:24 AM   #10
Yes I believe that is the case from what I have heard now in these comments.
The combination of very cold water and higher Altitude are the cause....
I took your advice and turned down the water flow....and amazing hotter water...
Thank you....
Old 05-09-2021, 11:30 AM   #11
I agree the water temp. Going in is like 35°F...that's asking alot from the short time that it's in the heat exchanger....
Old 05-09-2021, 11:36 AM   #12
I'm on the setting for freeze protection.....
But I have tried the normal settings and it's the same...
Old 05-09-2021, 11:38 AM   #13
Ok sound like slowing the flow worked some
2001 Kenworth T2000
2008 Smart on deck
Old 05-09-2021, 11:39 AM   #14
Fred W
Tankless
Old 05-09-2021, 11:41 AM   #15
Yes I tried that....Thank you
Old 05-09-2021, 11:46 AM   #16
llamb's Avatar
Glad you've been able to resolve the issue. Also good to know the Truma can keep up, but it does have it's limits.
Larry
2016 RAM 3500 DRW
Old 05-09-2021, 11:52 AM   #17
Thanks to everyone for all your advice....
I will repost when I get off this mountain....lol
How about that my neighbour is having the same problem.....
Old 05-09-2021, 11:53 AM   #18
Tom in Ohio's Avatar
The setting for freeze protection only works IF you have installed the optional heated filter assembly.
I installed one on my Isata 5 and it is worth the money!
Tom in Ohio
2019 Isata 5 30FW
Tom in Ohio is offline   Reply With Quote
Old 05-09-2021, 11:55 AM   #19
RedLdr1's Avatar
Thank you....
Thanks for posting the solution for the issue. We're planning on having a Aqua Go installed and heading out west in to the Rockies. Now with any luck I'll have one less "Duh" moment.
Wayne and Christine
2022 Sunseeker TS2380AFT On Order
2021.5 R-Pod RP-192
2020 Ford Expedition Platinum 4X4
3.5L EcoBoost 400HP with 480 lb.-ft. of Torque
9,200# Heavy Duty Tow Package with 1,524# Payload
RedLdr1 is offline   Reply With Quote
heater, water, water heater
