Old 11-28-2020, 03:30 PM   #1
TTPMS Compatibility Question
I just purchased a new 2021 Forest River Rockwood Mini Lite 2507s that came with the TST Tire Pressure sensors in the tires (TST 507 Series). I have a 2021 GMC Yukon that has the capabilities of monitoring trailer tires that have the sensors in them. The Yukon came with valve stem sensors that are labeled 4T. My question is, should the TST 507 sensors that are currently in my trailer tires work with my GMC's on-board monitor or will I need to remove the TST 507 sensors and put in the GMC 4T valve stem sensors for the GMC monitor to work? My trailer came with a TST color display monitor but I want to use the display that is in my Yukon so I don't have to use a separate monitor for the tires.
Mr. Ed is offline   Reply With Quote
Old 11-29-2020, 08:13 AM   #2
SeaDog's Avatar
I'm not sure how the factory GMC system works with that in mind I would wonder if the truck display system would show an alarm when you unhook from the trailer and pull out of range of the sensors?
Retired Navy
2016 Flagstaff 26 FKWS
Old 11-29-2020, 08:56 AM   #3
Ask yourself,"will the GMC valve stems fit your Trailer wheels"? Can you change the Pressure setting on the GMC valve sensors to accept the Trailer Tire pressure ? Youroo!!
Old 11-29-2020, 09:13 AM   #4
Let me clarify... The valve stems came with the Yukon as part of their max trailering package are specifically made to install on a trailer. There is a way to set the tire pressure and temp for the specific trailer. I am just trying to avoid having the replace the ones that came already installed on the trailer.
Old 11-29-2020, 09:15 AM   #5
nomad297's Avatar
I would go with the GM OEM valve stems just so I didn’t have to worry about any unforeseen problems.
Bruce
Old 11-29-2020, 10:02 AM   #6
wmtire's Avatar
Internal TPMS transmit on a few different dedicated frequencies. You may want to see what frequency the TST's transmit on and also the GM ones. 315 and 433 ranges are the two common use.
2011 Flagstaff 831 RLBSS
I often say to myself, "I can't believe that cloning machine worked."
Old 11-29-2020, 10:21 AM   #7
The GMC sensors say 433Mhz. The TST says 433.92 Mhz. Not sure it this means they are different or not.
Old 11-29-2020, 10:28 AM   #8
nomad297's Avatar
That is the same. 433Mhz is just short for 433.92Mhz.
Bruce
Old 11-29-2020, 10:33 AM   #9
rsdata's Avatar
I don't believe the built-in sensors will interfere with the add-on sensors. Just screw-on the GMC sensors and try it on the GMC display
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 11-29-2020, 10:59 AM   #10
The new GMC trailer 4T tire sensors are not the type that screw onto the valve stem. Rather, they are valve stems that mount inside of the tire like a normal valve stem.
Old 11-29-2020, 03:47 PM   #11
Even if the frequency of the two systems are the same they still may not work as the software protocols may be different; I.e. one speaks French but the other only understands English
WanderMore is offline   Reply With Quote
Old 11-29-2020, 04:07 PM   #12
Even if they "spoke English" there are all kinds of variations. US? UK? Australian, or even Southern and Cajun
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 11-29-2020, 04:08 PM   #13
Exactly!
Old 11-29-2020, 11:22 PM   #14
Sounds like you were right about speaking different languages. Got an answer from TST Customer Service today... "Because our system is proprietary it unfortunately does not communicate with your GMC. Most of our customers who want to use only 1 screen, add external sensors to their systems so that they can monitor the truck and trailer on the TST display. All 507 sensors are compatible with one another". I'd rather my one screen be the GMC's screen so I will be having the GMC valve stem sensors installed on the trailer.
tpms
