Old 06-07-2017, 08:36 PM   #1
JimFitz's Avatar
Thumbs down Valve Stem on Dually
I thought after reading this forum that I had seen it all. NOPE. I just took my Class A Georgetown to Ford for service. They told me they couldn't check the air pressure on the outside tires. (I know I should have checked them often, but...mybad....I will.) Anyway, the inside tires have a valve stem extension that comes out through the outer wheel. The OUTER wheel valve stem is on the interior side...between the tires. I (and Ford) can't check it. And I have no idea how I am going to get the TPMS on to that valve stem that I can't get to. I am really confused (and angry.) WHY would FR put the outer valve stem on between the tires where you can't get to it. Any thoughts/ideas???? Thanks. Fitz
JimFitz is offline   Reply With Quote
Old 06-07-2017, 08:42 PM   #2
Kanadian Kamper
kenandterry's Avatar
I'm not sure FR installed the valve stem. Maybe it's a Ford problem.
The bare bones chassis comes from Ford and I really doubt Forest River needs to remove wheels during construction of a motorhome on top.
Not sure who really installed the wheels....just be careful finger pointing.
Just sayin'.
Ken and Terry
2018 Sunseeker 2430S with Trekker cap
and only rarely pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 06-08-2017, 02:46 AM   #3
RUN... don't walk... away from that Ford dealership. Apparently they don't have much experience with HD dually trucks and such.
Most duallys use the same rim for inside and outside, just flipped around. Naturally both valve stems end up between the tires. Google "dually valve stems" for ways to make access easier, your local tire shop probably has those.
TheGerman is offline   Reply With Quote
Old 06-09-2017, 04:54 PM   #4
Steeljag's Avatar
I agree that's a Ford issue, and not a FR install !
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 06-10-2017, 04:10 PM   #5
longhunter's Avatar
Thumbs up Dually Valves!
Google Dually Valves, have them installed, end of problem!
I had them done, and it's easy to add air or check the air pressure. TPMS are east to install also!
Longhunter
Northern Illinois
2015 Sunseeker 2300
longhunter is offline   Reply With Quote
Old 06-10-2017, 10:27 PM   #6
camaraderie's Avatar
You can remove the hubcaps and get at them if they're anything like mine but you still can't use just any pressure guage to measure them...I tried a few before I found one I could get in that space with the hubcaps off. If you haven't removed them yet...just loosen the nuts (3 per hubcap) that have the line _____ on the body. Pain in the butt.
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
Old 06-11-2017, 07:19 AM   #7
Wolverine 1945's Avatar
On our Sunseeker I hold the extenders with Needle Nose Plyers with one hand and add air with the other,,, and YES it is a PITA !!!
It can be very helpful if you have a third hand !!!
Wolverine 1945 is offline   Reply With Quote
Old 06-11-2017, 11:09 AM   #8
On Sunseeker I had to remove the rear hubcaps to check air pressure. Will add extensions.
Fergie272 is offline   Reply With Quote
Old 06-12-2017, 07:46 AM   #9
Yes removing the rear Hub Caps does help,,, the extenders on ours are flexible,,, that is why I have to hold them to check or add air,,, I just this spring purchased an automotive style air chuck,,, like the ones we used to use in gas stations,,, with built in gauge,,, only works with 3 hands on flexible exertions !!! Also be very careful sticking your fingers thru the Hub Caps !!!
Or you could end up with bloody Hub Caps !!!
Old 06-12-2017, 09:06 AM   #10
Steeljag's Avatar
I'm soon to be looking / purchasing new / better stems for both the duallys and front tires.
Any recommendations on make ?
1930 lbs CCC
Old 06-12-2017, 09:14 AM   #11
You may want to search Valve Stem Extenders here,,, there has been much talk about extenders,,, I would recommend you do not buy Flexibility ones !!!
I think you would have to have a tire shop install the new ones ???
That is why I keep screwing with the ones I have !!!
GOOD LUCK !!!
Old 06-12-2017, 10:16 AM   #12
longhunter's Avatar
Yourtiresupply.com is where I bought mine! Great customer service and great product!
Longhunter
Northern Illinois
2015 Sunseeker 2300
Old 06-12-2017, 02:28 PM   #13
Steeljag's Avatar
GOOD LUCK !!!
Nothing flexible, something solid, and easy to check & add air pressure!
And yes, Tire shop will be installing.
1930 lbs CCC
Old 06-12-2017, 02:40 PM   #14
Darmo15's Avatar
You need 135 degree metal valve extensions. I just bought some Saturday at Camping World.
Daryl
2014 Georgetown 351ds
Darmo15 is offline   Reply With Quote
Old 06-12-2017, 02:55 PM   #15
lickem66's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2016 FR3 28DS
Past 2012 Forest River Rockwood 2104.
lickem66 is offline   Reply With Quote
valve
