Old 12-03-2021, 01:45 AM   #21
A Mile High & a Mile Deep
pcsdpo's Avatar
If the adhesive shows through the bottom (probably the solvent used in the adhesive reacts with the flooring), I wonder if the flooring is any good itself. Based on some of the quality of other materials used by FR, the flooring could just be heavy-duty Contact (r) paper . . .
"I would rather wake up in the middle of nowhere than in any city on earth." - Steve McQueen
pcsdpo is offline   Reply With Quote
Old 12-03-2021, 10:54 AM   #22
It's a lot of effort, but they should be able to do it in one piece. I did it on an old Keystone. Just made a giant pattern with rosin paper and cut it out accordingly. You need to be careful putting it down to avoid ripping at the doorways, but it can be done and make a much better finished floor.
Stevemal is offline   Reply With Quote
Old 12-03-2021, 08:22 PM   #23
My '19 Cardinal Limited has the exact same yellow stain where the corner of the dining slide meets the main floor. The stain is on the main floor right at the bottom of the fluted slide trim.
Unfortunately I bought this used so I am on my own.
FirstFiver is offline   Reply With Quote
Old 12-04-2021, 08:29 PM   #24
We have this as well in our toy hauler. FR approved the claim with no issue. We made a deal with our dealer to install higher quality diamond patterned rubber that is way more durable, easier to clean and will not show the glue. It may cost us some money for the upgraded floor but we will be happier and have something that should have been installed from the factory.
BTW, they only glue the perimeter of the floor so they don't get cold weather cracking which leaves the center open to potential damage from objects shifting on the floor while traveling. Also saves on glue and labour. No one would ever install a floor like that in a house.
Stryker Guy is offline   Reply With Quote
Old 01-28-2022, 12:44 AM   #25
Nope I install flooring and nothing takes out glue thru stains.
The only thing I could recommend is if you bought it through Camping World have them contact the Camping World in Columbus Minnesota they have a vinyl installer that they have on hand that does color match melting???
Might make it less noticable
Khtie is offline   Reply With Quote
Old 01-28-2022, 12:48 AM   #26
Ya but what can we do? Me and my wife have 2021 and literally get zero help and no recourse? We bought thru camping world but when u say unacceptable then what???
Old 01-28-2022, 02:52 AM   #27
bikendan's Avatar
Not sure who you are responding to.
Did you post this in the wrong thread?
floor, flooring
