Originally Posted by GAGator
Ok, here is an update on my wasp hunt/kill adventure. I finally had to get a fogger to chase them out and another 20-30 came out in a hurry. I just held it up to the vents and fogged inside. So... the wasps are gone, two HUGE nests have been destroyed, and the vent cover is now in my workshop where I am going to screen it. Thanks for all the excellent suggestions. Since I have plenty of scrap screen left over from re-screening the back porch, I'm going to screen everything with a hole.
Don't use the fiberglass screen material on the water heater and furnace vents, else you may have ignition! Any wire type screen will work just fine. I used aluminum screen wire and hot glue on the refrigerator and just the screen wire on all the other vents.
Be careful with the wasp spray around any open flames .... you don't need a flame thrower! When you are done, you should blow out all those passages with compressed air before reassembly. No point in saving the wasp corpses and associated debris.
Good Camping
Swampy
