07-11-2020, 07:27 PM
Water heater and fridge
On my 2019 290BH Tracer neither my fridge or my water heater is running off of propane. Does anyone have any suggestions on what’s going on? I’ve got propane going to my outside grill and my inside stove so not sure why propane’s not working on the fridge and water heater
07-11-2020, 10:09 PM
Just to make sure.... you're not plugged in?
Usually the water heater has a separate switch to turn it on.
The refrigerator has to be set to 'auto' or 'gas' to run off propane.
The other thing you can check is your battery. Both the fridge and water heater use an electronic ignition and that runs off your battery.
2015 Dynamax REV 24TB class C
07-12-2020, 07:47 AM
both the fridge and the water heater have a 12 volt control board that is used to initiate the propane burner. the grill do not have these. do you have 12 volt power to the refrigerator and water heater?
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
07-12-2020, 08:52 PM
So the water heater works. Still no luck with the fridge. I checked breakers and they are all good.
07-12-2020, 09:25 PM
I'm new to RV as well. Having same issue. Stovetop is good but can't get water heater to run off propane. Someone speculated it was air block. if so, how do I purge lines ?
07-13-2020, 12:25 PM
PCK - If you have an exposed gas line under the trailer, near your water heater, you could loosen the fitting until you smell gas.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
07-13-2020, 12:33 PM
For both Ryan and pck,
Have to tried purging the gas lines by lighting the stove for a couple of minutes to get the air out of the lines?
07-13-2020, 12:37 PM
The propane devices have a fail safe mechanism that activates after several failed attempts to start. Since the fridge uses the least amount of propane if there is any air in the lines it may fail to start enough times to trigger the fail safe. To reset the control board, pull the 12V fuse for the fridge wait a few seconds then reinsert. Retry the fridge. When ever you have not used the Rv for a while it is always best to start a stove top burner until it burns steady to purge the lines.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-13-2020, 04:49 PM
Have you check the regulator at the tanks
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
07-13-2020, 04:50 PM
Check for cob weds inside the tube run a round brush thru it
07-13-2020, 05:09 PM
No, no
No, no. Way too much trouble. Just light the range burners and let them run for 30-60 seconds.
Then the water heater, fridge, and furnace only have to purge a few feet of line.
Larry
07-14-2020, 06:40 PM
The fridges pilot light is running but the fridge is not staying cold. So not sure what to check next!
07-14-2020, 06:44 PM
Is it level?
07-15-2020, 07:14 AM
Originally Posted by NavyLCDR
Is it level?
How hot is it there where u r camping and also is the sun beating down on the outside of the camper where the fridge is
07-15-2020, 07:23 AM
Pilot Light ? or do you mean the Burner ?
07-15-2020, 07:25 AM
Just checking you do know it takes a long time (hours) for the fridge to get cold.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
07-15-2020, 08:44 AM
Two trips ago it was in the low 90s, and no shade. A/C had a hard time keeping up but no issues with my 3 cuft absorption fridge. Although, come to think about it, that was on AC power, not propane. And maybe the inside temperature being 75 most of the time helped.
Sorry, might really be comparing apples to oranges here.
07-15-2020, 09:07 AM
Reading through the posts, I've not seen you list the make/model of the refrigerator? Having that information will help us help you.
Typically smaller refrigerators that have a pilot light (you mentioned this in post # 12) operate differently than more automated R/V refrigerators with control boards.
We are all just guessing at this point.
07-15-2020, 09:37 AM
the week of the 4th when I was in Ohio it was around 95 the whole time except at nite and my air run the whole time and it didn't drop below75 either but my fridge was fine also
07-15-2020, 11:44 AM
The fridge is a Dometic. As for it taking a long time to cool I realize that but it was running the entire nite prior to us leaving and it never cooled down. Once I turned it to electric it started cooling right away. The pilot but I guess the burner is on. when I turn it to gas I hear the clicking and then the Flame starts but that’s it.
