Old 05-17-2024, 08:08 PM   #1
Water in underbelly
Someone left a faucet on and the tanks filled and overflowed into the underbelly. I saw water dripping from under my trailer. I got the water shut off and emptied the tanks. Got the sink and shower emptied.
But I see there is water in the underbelly cause its swaying down.
Is there insulation in there that will get ruined?
Its a 2022 Forest River Arctic Wolfe Cherokee
SFreshour is offline   Reply With Quote
Old 05-19-2024, 09:56 AM   #2
Mine has pink fiberglass insulation. That stuff can wick a lot of water and take forever to dry. Drying is important because you don't want the moisture under the floor. You can cut a drain hole to get the majority out, or park on a steep bank.
2019 Palomino Solaire 147X
2013 Ford F150
TacomaJoe is online now   Reply With Quote
Old 05-19-2024, 10:14 AM   #3
Georgia Rally Coordinator
aceinspp's Avatar
As recommended drill a hole to help drain any water. Later RD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 05-19-2024, 10:31 AM   #4
And a dehumidifier capable of drawing water out of walls. Air conditioning will also help draw water out of the rig.
Water shouldn't have flowed from the tanks into the underbelly unless you've got a leak in the plumbing. Overflow from the sink and shower will seep into the underbelly.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
underbelly, water
