While it's impossible to know for sure from just reading your post. It does sound like your grey tank got overly full, perhaps from the faucet not being turned all the way off?
If you want a quick and easy check to see if you have a pluming leak, add water to your fresh tank and turn on your water pump. If there is no leak, your pump should run until pressure is build up in your water lines then shut off. If it runs for more than a few seconds or runs intermittently despite all your faucets being turned off, that could indicate a leak somewhere.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
