Originally Posted by Flybob
The good news is that the line from the FW tank and the pump is a nylon reinforced hose so it will not be damaged by the ice. As for the enclosed underbelly that is just Coroplast and will do little to hold heat in on a very cold night. The furnace may have a single vent in the underbelly, but may be located in the other end of the unit from the FW tank. Best bet when hunting in cold weather. Bottled water, outside toilet or porta-potti with a winterized unit.
Not much of an option if i want to keep my wife coming.....
I️ need to open the underbelly soon to beef up the water tank supports. I’ll just have to asses it from there
So far I’m looking into adding 120v tank heaters ( we run a 3500 watt inverter generator through the night to let things charge)
Dump valve heaters, tape heaters for the water lines under the trailer. And insulatingnall of it at the same time.
The way i figure 12v heaters will do me no good. Just kill the batteries.
