Old 12-30-2019, 04:04 PM   #1
Water pooling above Coroplast
Heavy rain every day in Florida.
FR Sierra 377FLIK 5th wheel.
See that water is pooling on Coroplast which is drooping because of weight.
I am trying to figure out if rain water is finding it's way onto Coroplast or if I have a leak in plumbing.
Has anyone had this issue on their's?
No leaks inside.
2016 FR Sierra 377FLIK
2016 GMC Sierra 2500HD Diesel
ktvaughan is offline   Reply With Quote
Old 12-30-2019, 04:31 PM   #2
Always Learning
More likely to be a leak in the plumbing somewhere. It could be somewhere that you can't see. I literally just fixed a leak on Saturday. It's in my basement/deadspace area behind a partition that you never have a reason to take down. Turns out this has likely been leaking for months if not longer based on the amount of damp wood I'm seeing.
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
Old 12-30-2019, 06:41 PM   #3
007matman's Avatar
I'm gonna bet it's a plumbing leak too. It's pretty difficult for a roof leak to present itself there if it's not inside the RV.
007matman is offline   Reply With Quote
Old 12-30-2019, 06:55 PM   #4
Coach
I can say we had a shower drain vibrate loose and cause a similar problem once.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 12-30-2019, 07:27 PM   #5
Yes, it has been raining in Florida.
Do not know how your Coroplast is attached, but I do recall an old post that had same problem, As I recall the Coroplast extended past the rear edge of the Rv and rain water was running just the right direction to run on to the Coroplast.
Rich5117 is offline   Reply With Quote
Old 12-30-2019, 07:53 PM   #6
drill a 1/4" hole at the lowest spot and let the water out. Then watch it when it stops raining.
Old 12-30-2019, 09:14 PM   #7
I just found the leak.
They ran the flexible water line for the ice maker.through the metal cross braces underneath.
Looks like sharp metal edges nicked the water line.
I should be able to splice out the leak.
Has anyone used the PEX tubing crimpers?
Is it obvious once you buy the tool?
I need to join solid blue PEX tubing to braided flexible line.
Old 12-30-2019, 11:20 PM   #8
Always Learning
For transitions like that, I just use the regular screw hose clamps.
Old 12-31-2019, 12:56 PM   #9
I replaced plastic union with metal and tightened screw hose clamps down tight.
All good now.
Installers routed braided hose thru metal crossbraced and sharp edges nicked hose.
I re-routed to prevent future repeat.
Old 12-31-2019, 02:32 PM   #10
U.S.ArmyVeteran's Avatar
All good now.
Nice Work on your part
"Installers" being a relative term.
We are thinking about upgrading from a Dutchman. Alas, bad workmanship follows........Ughhh
U.S.ArmyVeteran is offline   Reply With Quote
Old 12-31-2019, 02:45 PM   #11
Coach
Pex tools aren't hard to use, but if you don't have a set already and don't foresee a great need for them, you could try a shark bite fitting if that will work on both pipes. They basically just press on and can be removed using an open end wrench as a press on the end. They're a little pricey, but a good option if you don't want to deal with getting pex tools.
Old 12-31-2019, 03:41 PM   #12
x2 on using shark bites. easy to use and they really work
ottawapaul is offline   Reply With Quote
Old 12-31-2019, 09:12 PM   #13
You can get a tool and a few lex clamps on Amazon for $25 or so. Easy to use.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
water
