Water pump keeps blowing fuses
Last winter I went to winterize my RV and when i turned the water pump on, the fuse blew. I tried another fuse, same result. So after a little research I saw that some people had luck changing the pump switch. So I ordered one, replaced it and voila, it started working. I guess these switches short out internally.
So now i'm in the process of dewinterizing and sanitizing the lines. i just filled my tank for the 2nd flush and turned the water pump on and the fuse blew again. I'm going to order a new switch, and actually have a whole new tank monitor system that i can probably use for the moment as a replacement switch, but i'm worried theres another issue. i understand theres a relay because the power coming out of the switch is definitely not 12v. Is there a way to test the relay? what else could be causing the fuse to blow? The first time this happened i disconnected the pump and jumped it with my 12v battery jump-start box and it worked fine. I went through sanitizing and the first flush before this started happening again. very frustrating to say the least.
