Old 02-14-2020, 12:24 AM   #41
Water pump sucking
We have a 2014 forest river georgetown, we had this same issue. Changed out pump and filter housing but we discovered that our filter housing was cracked under the label with the name of the part on it. Seems simple but made us work hard to figure it out,
Phabibzadeh is offline   Reply With Quote
Old 02-14-2020, 10:01 AM   #42
Water pump
Check to see if the valve is open that is used to suck fluid into the water system to winterize. Had this happen to me.
Steve Phelps is offline   Reply With Quote
Old 02-14-2020, 07:03 PM   #43
Being an old body man I may recommend a stethoscope to find air leaks . When the end goes over an air leak or water leak the sound gets louder making it easier to find . I still use mine but I have added an extra length of tubing to make it easier to use . Just a thought that may help you .
tasniroc is offline   Reply With Quote
Old 02-14-2020, 07:17 PM   #44
In my Freelander Micro if the screen filter/anti-syphon valve (at the fresh water inlet) is compromised, the pump will suck air.
Woody & Cookie
2017 Coachmen Micro 20CB (Livy)
2015 Smart Fortwo (Huck)
New Hampshire
Wood2Cook is offline   Reply With Quote
Old 02-14-2020, 08:04 PM   #45
We have a Rockwood Mini Lite 2109s and the water pump and the filter are located under the bathroom sink. It is reasonably accessible there. Maybe they switched the location of the plumbing in the 2020 model because of the difficulty to access it.
HB Neil
2020 Rockwood Mini Lite 2109s
190 Watts Go Power Solar
2020 Toyota Tacoma
Anderson WDH
Huntington Beach, CA
hbneil is offline   Reply With Quote
Old 02-15-2020, 08:33 AM   #46
You did see two posts above yours where the OP took their R/V to the dealer where they found a crack in the Showermiser line?
Days Camped: '17=30 '18=51 '19=58 '20=98
pump, water, water pump
